Cam question
Cam question
All things being equal in a '68 Toronado 455 engine, how would this cam behave in the different RPM ranges (with 9.6:1 compression) vs the stock Toro camshaft and 10.25 compression?
Advertised Duration (Int/Exh): 262/268; Duration @ .050 (Int/Exh): 219/227; Gross Valve Lift (Int/Exh): .499/.510; LSA/ICL: 112/108; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1300-5500
https://www.lunatipower.com/voodoo-h...8-262-268.html
Thanks.
Thanks.
