1972 Toronado coolant amount for fresh radiator
Old Jun 9, 2023 | 09:16 PM
Brian.james.delong's Avatar
Just replaced the radiator and Hoses in my 72 Toro.... how many quarts of coolant should I be expecting to put in?
Old Jun 9, 2023 | 09:35 PM
cfair's Avatar
My ‘66’s with 455’s take 17 quarts or ~4.4 gallons with overflow (aka puke) tank installed and a 16lb cap.
When I pull the radiator hoses I’ve taken to refilling with 2 bottles of water wetter, 70% distilled water & 30% antifreeze.
My rationale is that water transfers heat better than antifreeze, water wetter helps keep things cool through the magic of chemistry, antifreeze is mainly there for the lubrication it imparts to the engine.
If freezing is a part of your annual experience, go with the more ordinary 50/50 mix, water wetter optional. Here in the SF Bay Area, we don’t get to freezing too often, so I worry more about overheating in traffic.
With luck you’ll get a response from someone with more knowledge about ‘72 Toro’s than me, but here’s a starting point.
Chris
Old Jun 10, 2023 | 08:56 AM
Thanks Chris. I've heard 17 is about what I need, just wanted someone with actual hands on experience to verify. I appreciate it!
Lilly XS
Jun 10, 2023 10:31 AM
Angela_barlow
Oct 29, 2022 03:01 PM
'66toro
Feb 16, 2022 01:49 PM
jackrhutton
Oct 16, 2014 10:57 PM
cadillac kevin
Aug 21, 2014 09:13 AM
