push rod hole
Old Jun 11, 2023 | 05:23 AM
doggonn's Avatar
push rod hole
are the new edelbrock head pushrod holes work on a 1965 A engine or do they have to be machined . are there any other modifications needed to make them work
Old Jun 11, 2023 | 09:24 AM
Duh's Avatar
Duh
If using 3/8 pushrod it's possible to hit at the bottom of the holes. Regardless of heads used any 65 BBO using B block and early E castings should check for interference at the deck.
Old Jun 11, 2023 | 02:40 PM
doggonn's Avatar
push rod
i guess edelbrock might be able to tell me if i have clearance and what diameter pushrod to use i wish someone on this site has used the new edelbrock head and if they had issues . 1965 425 a motor has a odd cam bank angle. need some advice
Old Jun 12, 2023 | 06:55 AM
sysmg's Avatar
Place the head on the block and try the pushrod with the rocker installed. If it interferes or is close take the head off and drill out the pushrod holes. Went through a number of drill bits doing this to an E head for a 66 45 degree block.
Old Jun 12, 2023 | 01:12 PM
Duh's Avatar
Duh
I don't think they will. I have used Gen2 with 45 degree blocks and 3/8. I moved the holes towards the deck about .110 (one hundred and ten thousandths). Call a reputable shop that knows the difference between the 39 and 45 blocks and have them do it
Old Jun 12, 2023 | 02:52 PM
doggonn's Avatar
thank for your input
ben442
Sep 3, 2023 05:11 PM
Andy1984
Apr 3, 2019 08:44 AM
mazey
Oct 10, 2017 03:21 PM
boese1978
Mar 8, 2016 03:49 PM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
