Engine expert advice
Old Apr 17, 2023 | 07:25 PM
zekecut70's Avatar
I put a new Electric fuel pump on the 455 this weekend .When I clicked on the ignition, to set the fuel psi on the regulator the psi spiked to 15 psi blowing past needle and seat filling my cylinders with fuel. Took all spark plugs out and cranked engine until all fuel was pushed out. Drained oil and refilled with new.. Now the question is... should I squirt oil in the cylinders before I start up? Or should I be fine. Concerned about "cylinder wash out". Or am I overreacting? Thanks.
Old Apr 18, 2023 | 04:46 AM
Don't over think it. You mentioned you already cranked the engine over to evacuate the cylinders of fuel.
Old Apr 18, 2023 | 04:30 PM
When you start it, plan on lots of black smoke until it’s cleared out. Depending on how long it sat with the engine filled with fuel you might consider changing the oil.
Old Apr 18, 2023 | 04:58 PM
REO442's Avatar
Already have the plugs out. Take advantage of being safe on the wash-down potential, squirt some oil into each cylinder, crank it a few turns, put the plugs in, then start it.
louie
Jul 11, 2022 07:24 AM
kingoftoys
May 22, 2020 10:21 AM
OLE442
Sep 28, 2019 10:24 AM
ankerclanker
Jun 10, 2017 02:31 PM
Nasty455
Sep 7, 2012 09:42 AM
