Engine expert advice
I put a new Electric fuel pump on the 455 this weekend .When I clicked on the ignition, to set the fuel psi on the regulator the psi spiked to 15 psi blowing past needle and seat filling my cylinders with fuel. Took all spark plugs out and cranked engine until all fuel was pushed out. Drained oil and refilled with new.. Now the question is... should I squirt oil in the cylinders before I start up? Or should I be fine. Concerned about "cylinder wash out". Or am I overreacting? Thanks.
kingoftoys
May 22, 2020 10:21 AM
