Cheap oil pan suggestion
Old November 25th, 2021, 02:41 PM
Bastler's Avatar
Hello,
for my winter build i am searching for a bigger oil pan.
It should fit my 1970 442 A body. I found the milodon and moroso oil pans but i also found cheap 8qt oil pans at ctrperformance and assaultracing.
They are very cheap, do you think i should give them a try? It is for a street/strip car.
https://www.cfrperformance.com/1964_...z.htm?CartID=1
https://www.assaultracing.com/item/2...55-8qt-blk-pan
Bastler is offline
Old November 25th, 2021, 03:18 PM
CANADIANOLDS's Avatar
Ive used the anodized one before..it fit good , they are the big block style pan with the factory style baffle.
identical to the milodon/moroso street strip style basic big sump pan.
I have one here going on a customer’s engine..I can post pics of the inside sump if you want
CANADIANOLDS is online now
Old November 25th, 2021, 03:21 PM
Bastler's Avatar
This would be very nice. Thank you a lot
Bastler is offline
Old November 25th, 2021, 06:17 PM
cutlassefi's Avatar
I get that you’re looking for a cheap pan, but you should also consider the Canton 15-502. 6qt with trap doors and extremely well made.
cutlassefi is online now
Old November 25th, 2021, 07:41 PM
Pan and the matching pump pickup. Speedmaster
Old November 26th, 2021, 04:16 AM
Bastler's Avatar
thank you for the answer. The canton isnt available and only has 5qt. My toro pan also has 5qt.
Maybe i buy the 8 qt and weld in a extra oil trap?
Bastler is offline
Bastler's Avatar
Thank you for the pictures.
Bastler is offline
Old November 26th, 2021, 05:17 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
That pan looks pretty good for the price. There is also the Thornton pan. Mark got me a Canton pan and pick up not very long ago. There is a swinging side baffle as well. It is a 6 quart pan, really nice.
olds 307 and 403 is offline
Old November 26th, 2021, 05:30 AM
Bastler's Avatar
I think i will take the canton also.
there are too many gurus that say to take the canton
Bastler is offline
Old November 26th, 2021, 06:45 AM
My442's Avatar
Exclamation
Be careful on the depth. The sump can hang below the crossmember.
The Milodon 7 quart pan sits level with the crossmember.
My442 is offline
Old November 26th, 2021, 06:56 AM
I have to be honest. I wouldn't use the words "cheap" and "oiling system" in the same sentence.
joe_padavano is online now
Old November 26th, 2021, 07:59 AM
Bastler's Avatar
you are right. I ordered the canton pan, to get sure that are no oiling issues.
Bastler is offline
Old November 26th, 2021, 01:46 PM
cutlassefi's Avatar
You are right. I ordered the canton pan, to get sure that are no oiling issues.
Good move in my opinion. Couple that with restricted pushrods and you’re all set.
Old November 26th, 2021, 10:05 PM
cjsdad's Avatar
This is the Canton on a 350 block in a 67 Cutlass with new motor mounts. It is a bit lower than the front crossmember but I figure if I manage to drag it on something, I shouldn't have been there. I do my offroading in my 4X4. Those headers are for a BB Olds so that is why they hang down so far.
cjsdad is offline
Old November 27th, 2021, 05:54 AM
Good to see and what I figured. My aluminum trans with be the lowest point on my 70S.
Old February 24th, 2022, 06:34 PM
MO Olds 2022's Avatar
Do you suggest not going with CFR performance then per the link above/picture below? I agree not to be cheap when it comes to oiling but wasn't sure if CFR is considered good or bad (but $102 + shipping is cheap compared to other pans). Thanks!
MO Olds 2022 is offline
Old February 24th, 2022, 08:16 PM
VI Cutty's Avatar
Looks like the CFR one hangs 7/8" lower than the Milodon or Canton ones. 8 1/4 deep vs 9 1/8"...
VI Cutty is offline
Old February 25th, 2022, 05:41 AM
brownbomber77's Avatar
Almost worth it to buy it and cut an inch out of it and use the Canton or other pickup. There's a $200 difference. While you're at it, weld in your own baffle.
brownbomber77 is offline
chip-powell
October 29th, 2015 04:27 AM
oldsman71-69
June 14th, 2015 07:44 PM
badf85
February 26th, 2015 07:39 AM
dnmfranco
October 31st, 2013 12:40 PM
808olds
September 16th, 2010 08:13 PM
Quick Reply: Cheap oil pan suggestion
