Newbie from Ohio engine id
Old Mar 10, 2021 | 07:06 AM
M00SE's Avatar
I'm not knowledgeable on Oldsmobile motors and have a 455 that I would like to know more about. Specifically what it came out of.. what info is needed and where on the motor is it located would be very helpful. This Motor is very complete and I believe it's all original. I've had it for close to 25 years.. any help is greatly appreciated!
Old Mar 10, 2021 | 09:14 AM
Read through this thread:
Photos of Casting Number Locations, Engines - ClassicOldsmobile.com
Old Mar 10, 2021 | 02:29 PM
M00SE's Avatar
Thanks oldcutlass! I read through the thread you shared and have some pics of my Motor hopefully you or someone might help with decoding?
Old Mar 10, 2021 | 09:29 PM
The heads and VIN pad show it is a 1972 engine from the Lansing, MI facility.
Old Mar 11, 2021 | 03:36 AM
M00SE's Avatar
Thanks for the help Fun71. I found a site that listed the heads were used in W30's only. Any way to verify that?
Old Mar 11, 2021 | 04:19 AM
rob1960's Avatar
Ga heads were used across the board in '72. Some had the big valves(W30s & man. trans 442s, maybe Toros but I think they didn't get the large valves in '72) the rest had the smaller valves. I'm not positive but that partial vin (547326) on your block probably makes it a big car motor( small valve heads). Still a good engine for a starting point.
Old Mar 12, 2021 | 04:50 AM
M00SE's Avatar
Thanks Rob, big car motor is what I suspected in the beginning but the internet info sent me down a rabbit hole...
Old Mar 12, 2021 | 08:59 PM
hurst68olds's Avatar
32M547326
3 = OLDSMOBILE
2 = 1972
M = Lansing, MI assembly plant
547326 = VIN sequence number
400,000 & 500,000 VIN sequences for '72 LANSING were full size cars 88/98 (non-Toronado)
Old Mar 14, 2021 | 04:10 PM
M00SE's Avatar
Thanks hurst68olds I appreciate the info!
Chesrown 67 OAI
Nov 1, 2010 09:21 AM
munch
Oct 22, 2010 04:30 PM
new2thegame
Oct 4, 2010 08:02 AM
Batmobile66
Jun 17, 2010 05:24 AM
Navy guy
Apr 30, 2010 03:05 AM
