455 heat riser shroud
Old Feb 25, 2021 | 03:56 PM
BAMiller's Avatar
Getting a 455 ready to put in a 1970 cutlass I'm working on, i want to install the exhaust manifold heat riser shroud that fits over the exhaust manifold for the air cleaner heater or thermac. I am going to order a reproduction from inline tube. I don't have an old one to look at but I can't find any bolt holes on the manifold to bolt it to. What holds it on? I am using the stock 455 exhaust manifolds.
Old Feb 25, 2021 | 06:30 PM
tnswt's Avatar
'70 4-Speed W Machine
Perhaps this picture helps.......
Old Feb 25, 2021 | 11:27 PM
shiftbyear's Avatar
I'm not 100% sure but did they come with a screen in the top of the pipe?
Old Feb 26, 2021 | 06:52 AM
tnswt's Avatar
PIM 6-1; 136 specifies the screen filter assembly (230725) for the 455 CU.IN. "A" SMT, standard air cleaner. On the following page of the PIM it shows the OAI system with the same filter assembly specified; however, no distinction is made between transmission types.
Old Feb 26, 2021 | 09:58 AM
BAMiller's Avatar
Thanks, that pretty much clears it up!
Old Feb 26, 2021 | 07:14 PM
70Post's Avatar
BAMiller - just make sure to install the shroud BEFORE the engine goes in.
Old Feb 26, 2021 | 07:58 PM
tnswt's Avatar
Good tip 70Post, the OP sure will have a better outcome if he takes you up on your suggestion
yellowrocket
Aug 25, 2019 05:10 PM
matchek
Mar 16, 2015 04:23 AM
matchek
Mar 10, 2015 06:36 AM
SAMMAN
Sep 17, 2014 04:52 PM
tbirdman
May 22, 2014 03:27 AM
