394 Water Neck Spacer
Hi all.
I wanted to install a temp gauge without replacing the stock light. I have searched and found other threads but most people just recommend putting the new thermometer in the old light sensor area. I have also considered getting an adapter that you put in between two sections of the upper radiator hose. That said, I was wondering if anyone had any luck finding either a neck or a spacer that works with our 394s. I have seen them for other engines but cannot find one that works for ours. Any help would be appreciated!
Spacer example: https://www.summitracing.com/parts/m...028s?rrec=true
Neck example: https://www.summitracing.com/parts/t...UaAi23EALw_wcB
