Tighten them exhaust bolts!
Old Jun 25, 2019 | 11:17 PM
cfair's Avatar
I’ve had 2 big blocks in the garage for the past few days. Fun!
I’m also trying to harmonize their maintenance schedule to have less to remember.
I was doing a “tighten everything” session when I found my 98 with the rear driver exhaust manifold bolt loose. It’s happened before, unremarkable so I tightened it right up.
So, with 9/16’s wrench in hand, I checked the Starfire. Same motor, similar bolt-loose exposure. Drivers side rear was loose. Passenger side rear was _missing_. So I replaced it and tightened with a lock washer...
It wasn’t noisier, but the a/c did smell a bit off. I’m guessing from exhaust being drawn in...
Seems obvious, but a once in a while check for tight bolts helped me today. Perhaps you too, one day.
cheers
cf
Old Jun 26, 2019 | 04:33 AM
I replaced a lot of the hardware holding my front bumper with nylon locknuts. Some of the nuts just would not stay torqued. I have solid engine mounts, I’m guessing the constant vibration and flex loosen things up. Going on 3 years now and last time I looked things over everything was still tight.
Old Jun 26, 2019 | 04:59 AM
The heating/cooling cycle on exhaust manifolds/headers doesn't help. I always blow header gaskets. I just do yearly maintenance and replace them now. I've even tried fancy, expensive gaskets and the locking header bolts. They blow too.
Old Jun 26, 2019 | 04:42 PM
I switched from header gaskets to regular Fel Pro exhaust manifold gaskets and they have been working very well. No blowouts in, uh, lemme think. Well I have no idea when I put them on. Seems like a couple years ago but it's probably more like 10 or more years now.
1983NineEight
Aug 13, 2015 04:46 PM
Macadoo
Oct 6, 2013 10:29 AM
woody30
Sep 17, 2012 05:19 PM
veltboy618
Mar 24, 2009 09:08 PM
dynamic88
Nov 27, 2008 06:33 AM
