Bolt on z bar bracket for a 1973 455?
Old July 2nd, 2018, 04:38 PM
terry.holte@gmail.com's Avatar
Does anyone make a bolt on z bar bracket for a 1973 455? I found a bunch for chevy and ford @ Summit and Jegs.
terry.holte@gmail.com is offline
Old July 2nd, 2018, 06:13 PM
therobski's Avatar
Have not heard of one, bolt on or weld into position is a challenge-can be done but easier with motor out of the car-depends on your skill level, or $$$ spend for installation etc. I'm assuming the 455 is a donor motor. Questions: has the back on the crank shaft been drilled out for the pilot bearing to accommodate the 4-speed??? If you need more assistance, dive in and give us more details please.
therobski is offline
Old July 3rd, 2018, 05:37 AM
I doubt there is enough demand for an Oldsmobile bracket to justify a company putting one into production. Others here have made their own, supported by the bellhousing bolts.
joe_padavano is offline
RAMBOW
March 21st, 2022 02:48 PM
Cutlasskyle
Brakes/Hydraulic Systems
August 30th, 2017 07:44 AM
TWP442
April 20th, 2013 11:23 PM
76rckt455
December 26th, 2010 10:53 AM
bccan
September 30th, 2010 06:49 AM
Quick Reply: Bolt on z bar bracket for a 1973 455?
