Cast aluminum W30 intake restoration.
Media blasting would get it spotless. I'm not sure what media would be best to use though i.e. sand, walnut shells, glass etc. Since it's a cast aluminum intake and not body panels I guess you don't have to worry about warping anything.
Blasting with glass beads is the traditional way to clean aluminum intakes. Unfortunately, it leaves a surface that is slightly "rougher" than the original cast finish. I have not tried walnut shells but have some now and plan to.
I have used fine glass at lower pressure. It takes a while at low pressure but worked real well. I also had one that was real greasy and had some stains on it after I cleaned the grease off. The color was so good I did not want to blast it. I took it to a guy that has a large professional grade ultrasonic cleaner and turned out incredible.
I build an engine with an intake with perfect color and another one with a blasted intake. After it is in the car you can't tell a difference.
Thanks guys for the info. Think I will soak it in the pine sol then evaluate...wish I knew who locally has an ultrasonic cleaner. It is a factory W-30 manifold so I want to be careful.
i glass bead blasted my performer intake it was filthy and stained it came out great but i think a little darker and like Joe mentioned a little coarser.
I have a small ultrasonic at home and a big one at work, if the part is in good shape these will work to clean it beautifully, i have cleaned many small brass jets and MC carbs etc and they come out like new.
Wildcard
December 26th, 2012 07:48 AM
