Cast aluminum W30 intake restoration.
Old Jul 11, 2017 | 10:16 AM
dgp1042's Avatar
What is the best way to clean a factory cast aluminum W-30 intake to make it look new again?
Old Jul 11, 2017 | 12:33 PM
Media blasting would get it spotless. I'm not sure what media would be best to use though i.e. sand, walnut shells, glass etc. Since it's a cast aluminum intake and not body panels I guess you don't have to worry about warping anything.
Old Jul 11, 2017 | 03:10 PM
Blasting with glass beads is the traditional way to clean aluminum intakes. Unfortunately, it leaves a surface that is slightly "rougher" than the original cast finish. I have not tried walnut shells but have some now and plan to.
Old Jul 11, 2017 | 06:12 PM
wr1970's Avatar
Walnut may leave a residue. There are other soft strips. I would use walnut over glass or sand. JMO
Old Jul 11, 2017 | 06:26 PM
jensenracing77's Avatar
I have used fine glass at lower pressure. It takes a while at low pressure but worked real well. I also had one that was real greasy and had some stains on it after I cleaned the grease off. The color was so good I did not want to blast it. I took it to a guy that has a large professional grade ultrasonic cleaner and turned out incredible.
I build an engine with an intake with perfect color and another one with a blasted intake. After it is in the car you can't tell a difference.
Old Jul 12, 2017 | 05:38 AM
If you don't have a media blaster you can also soak it in a Pine Sol solution before removing the grime with a brush.
Old Jul 12, 2017 | 05:59 AM
dgp1042's Avatar
Thanks guys for the info. Think I will soak it in the pine sol then evaluate...wish I knew who locally has an ultrasonic cleaner. It is a factory W-30 manifold so I want to be careful.
Old Jul 12, 2017 | 11:54 AM
costpenn's Avatar
Best thing to do is send it to 70Post. It will look correct when you get it back.
Old Jul 12, 2017 | 12:50 PM
RetroRanger's Avatar
72 Olds CS
i glass bead blasted my performer intake it was filthy and stained it came out great but i think a little darker and like Joe mentioned a little coarser.
I have a small ultrasonic at home and a big one at work, if the part is in good shape these will work to clean it beautifully, i have cleaned many small brass jets and MC carbs etc and they come out like new.
tocicar8825
Sep 21, 2021 07:10 AM
Shradezz70S
Feb 19, 2014 10:21 AM
70F85
Sep 22, 2013 08:22 AM
Wildcard
Dec 26, 2012 07:48 AM
joepenoso
Nov 23, 2011 01:13 PM
