Positive Battery Cable Routing W/Headers
Old Aug 2, 2016 | 07:49 AM
1968_Post's Avatar
Any input on routing the positive battery cable in a 1968 442 with headers? Maybe I'm being a little reactionary, but running it between the header tubes seems a little risky. How have some of you approached this?
Jeff
Old Aug 2, 2016 | 09:26 AM
allyolds68's Avatar
Jeff
Why don't you run it over the valve cover and down the back like the four speeds cables are run
Mine isn't quite right because the cable is a couple inches too short:
Old Aug 2, 2016 | 09:30 AM
Or, over the fender well to the firewall and then down to the starter.
Old Aug 2, 2016 | 10:30 AM
1968_Post's Avatar
Thanks Mike & Eric... I was considering both of those routes. less stuff in the way if I go down the valve cover. Back down the fender well is the other, but there's more stuff in the way on that route.
Mike, if I'm not careful, I might actually have this thing finished this month... progress has been slow. I think old age has finally caught up with me.
Old Aug 2, 2016 | 10:42 AM
allyolds68's Avatar
Jeff,
Any progress is good.
I should really replace my cable because it loops under the z-bar anyway and rubs. It was an auto trans cable from a 350 car that I slapped in there. I did a lot of things incorrectly to get it going five years ago and I've slowly been fixing all my half-assed installations. This spring I put a real clutch in (Centerforce), added the Jeep Grand Cherokee Steering Box, put rear air bags in, aligned the passenger window (finally), and installed the faux core top plate I made years ago. Next year I'll repaint the hideous, incorrect bronze engine, install a nice set of polished aluminum valve covers I have, and generally clean up the mess in the engine bay.
Little by little........
Old Aug 2, 2016 | 11:09 AM
1968_Post's Avatar
I've been fighting back issues all summer and that plus the hot, hot days we've had since May have kept the progress to a crawl. The biggest issue I'm still having is the alignment of the power steering pump. I don't know if I have mismatched brackets or what, but the alignment just ain't right. Sooner or later, I'll figure it out.
Old Aug 2, 2016 | 12:29 PM
allyolds68's Avatar
This may be a stupid question but do you have the correct spacers behind the pump brackets?
Old Aug 2, 2016 | 01:46 PM
1968_Post's Avatar
As far as I can tell, yes. I started with a 1972 350 bracket setup. I then went thru the parts catalog and looked up whatever was different for a 455, which was the bottom link that goes to the block approximately below cylinder one. The pump seems to be canted back towards the firewall on the left side. I've tried a smaller space on the lower timing cover screw, washers at the top of the timing cover to space the bracket forward and a washer between the lower spacer and bracket, all to no avail. I've put everything back to normal now and removed the washers from behind the brackets. I also DO have the spacer between the bracket and pump. I'm thinking I may have to start over with the "H" and "C" brackets with all pertinent spacers.
Old Aug 2, 2016 | 01:57 PM
allyolds68's Avatar
Is this stud installed?
In 68 there's only one power steering pump configuration.
I used a 72 350 non-air bracket set for my car and everything lined up. I don't know what differences there may have been in 72 for A/C
Old Aug 2, 2016 | 02:16 PM
RetroRanger's Avatar
72 Olds CS
didnt see it in your pic apologies if its shown I cant see all the pics but do you have the spacer shown at the red arrow ?
Old Aug 2, 2016 | 02:50 PM
1968_Post's Avatar
Yes, it's there. I tried to take better pics but they came out too dark. It almost seems that the main mounting bracket is bent. I need to do a little more research on what I have. I thought I had everything sourced to the same year and engine, but maybe I missed something up.
72 Olds CS
also i think you have an extra washer on the top stud and a extra nut on the bottom stud circled in pic
Old Aug 2, 2016 | 02:55 PM
1968_Post's Avatar
That was an earlier pic. I removed the washers from behind the top bolt. The nut on the bottom is part of the stud. Wrong stud?
Old Aug 2, 2016 | 02:58 PM
1968_Post's Avatar
Mike, both spacers are there. Whether they're the right ones, well...
Old Aug 2, 2016 | 04:55 PM
72 Olds CS
i just checked an old pic that looks right w the nut behind the spacer
there is a sticky w the spacer sizes listed I ll see if i can find it
Old Aug 2, 2016 | 04:59 PM
72 Olds CS
here
https://classicoldsmobile.com/forums...p-spacers.html
Old Aug 2, 2016 | 08:16 PM
1968_Post's Avatar
Thanks Retro... I'm pulling it off and reassessing what I've got.
Old Aug 3, 2016 | 05:10 AM
allyolds68's Avatar
That's an excellent reference thread
jharsh
May 2, 2016 10:03 AM
kelly bakies
May 10, 2015 06:38 AM
ErikW
Mar 25, 2013 12:35 PM
matviar
Apr 2, 2012 05:18 PM
joepenoso
Oct 16, 2011 11:46 AM
