Big Block Info
Old Feb 9, 2016 | 04:53 PM
Scott Krafft's Avatar
Big Block Info
I recently purchased a 455 VIN derivatives 33m 68f4 behind flywheel The
The F is sans serif
396021F
E heads 403686
39736 CN crank
Are all these from the same engine, or a mix of years?
Old Feb 9, 2016 | 08:11 PM
don71's Avatar
same but different
As far as I can tell....
1973 block
1970 heads
typical crank found in 455, 1968-72
Old Feb 10, 2016 | 07:06 AM
The F is sans serif
396021F
E heads 403686
39736 CN crank
Are you sure the VIN derivative is 33Mxxxxxx and not 38Mxxxxxx? The former would indicate a 1973 block, the latter a 1968 block.
Old Feb 10, 2016 | 08:26 AM
It is very clearly stampted...33M101455
I thought it weird to, as all the other markings suggest a 68-70
Old Feb 10, 2016 | 09:37 AM
Octania's Avatar
I recently purchased a 455 VIN derivatives 33M101455
3 = Olds
_3 = 1973
__M = Lansing Asm. Plant
___101455 = sequential # of the car, #1455 off the line probably, very early.
Utterly meaningless. Disregard. Seriously.
396021F The F is sans serif
Any 455 pretty much. No new info here.
E heads 403686
1970 issue exc. W30
May have big valves, probably not.
Any indications of Tornado-ness? Angled oil filter mount, funny looking oil pan?
Sunken low intake?
39736 crank
They often machine away the last digit for balancing. The correct number is
397363. Photos exist showing this. No new info here either.
So far, I get "mixture"
Sounds like a fine mixture of parts.
Plans for it?
Old Feb 10, 2016 | 01:31 PM
Complete overhaul and put in my 70 Cutlass conv. frame off restoration
bocoogto
Aug 26, 2023 06:09 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
