What intake gaskets to use?
Goin to be doin some work on my 68 400 engine soon, what intake gaskets should I use regular intake gaskets or the tin valley
pan gasket type? Thanks!
The factory used the one piece tin gasket so called turkey tray gasket. For a stock intake I always use these. At first it was said by a well known Olds guy that this type of gasket should not be used on aluminum intakes but it is also what GM used. My opinion is the paper style gaskets squish too much and require frequent re-torqueing...
i have read that the performer was designed to use the turkey tray gasket. that is what i would recommend since it sounds like you are using a stock intake... matter of fact i think that any intake that is run with heads that don't have the crossovers blocked needs the turkey tray unless the bottom of the intake has been coated to resist heat...
I use a stock iron intake and heads, and always the turkey tray. People say the trayt is too keep the hot oil off the intake, but really I think it is more to keep oil from cooking on the heat riser passage of the intake manifold.
shamusj
December 18th, 2014 09:28 AM
JpMotorsports
May 15th, 2014 07:08 AM
Al2011
February 15th, 2012 03:57 PM
