What intake gaskets to use?
Old Mar 14, 2012 | 04:38 PM
Stevec's Avatar
Goin to be doin some work on my 68 400 engine soon, what intake gaskets should I use regular intake gaskets or the tin valley
pan gasket type? Thanks!
Old Mar 14, 2012 | 04:50 PM
cutlassefi's Avatar
I use Mr. Gasket #404 and paint the underside of the intake with Ceramic paint.
Old Mar 14, 2012 | 05:09 PM
Oldsmaniac's Avatar
The factory used the one piece tin gasket so called turkey tray gasket. For a stock intake I always use these. At first it was said by a well known Olds guy that this type of gasket should not be used on aluminum intakes but it is also what GM used. My opinion is the paper style gaskets squish too much and require frequent re-torqueing...
Old Mar 14, 2012 | 05:33 PM
Intragration's Avatar
I used the turkey tray on my 455 with an Edelbrock Performer and have no problems.
Old Mar 14, 2012 | 05:56 PM
bigD's Avatar
i have read that the performer was designed to use the turkey tray gasket. that is what i would recommend since it sounds like you are using a stock intake... matter of fact i think that any intake that is run with heads that don't have the crossovers blocked needs the turkey tray unless the bottom of the intake has been coated to resist heat...
Old Mar 14, 2012 | 07:22 PM
Run to Rund's Avatar
I use a stock iron intake and heads, and always the turkey tray. People say the trayt is too keep the hot oil off the intake, but really I think it is more to keep oil from cooking on the heat riser passage of the intake manifold.
Old Mar 15, 2012 | 06:42 AM
I agree!
Old Mar 15, 2012 | 01:19 PM
Stevec's Avatar
Hey Mark what kind of ceramic paint do you use and do you brush or spray it on?
shamusj
Dec 18, 2014 09:28 AM
JpMotorsports
May 15, 2014 07:08 AM
HitTheHole
Nov 25, 2013 04:31 PM
blackbird51
Jul 10, 2013 11:29 AM
Al2011
Feb 15, 2012 03:57 PM
