What Heads are these?
Old November 30th, 2017, 04:38 AM
Dolores's Avatar
Just acquired a 1967 Delta 88. Carb is a Quadrajet, block stamp is 389244D. However the number stamped on the front of the passenger side head is N681957 and even though I have the FSM I can’t reconcile this number. Any ideas?
Thanks!
Dolores is offline
Old November 30th, 2017, 04:59 AM
cutlassefi's Avatar
Just look for the letter code on the corner of the head.
cutlassefi is offline
Old November 30th, 2017, 05:46 AM
Maintained
scottv442's Avatar
Its the engine unit number and the letter is the model line.
N is for Delta 88 I believe. See link to post below.
https://classicoldsmobile.com/forums...s-engines.html
scottv442 is offline
Old November 30th, 2017, 07:28 AM
Dolores's Avatar
Found it - large B stamped on each head. So mine's a '66 motor in a 67 Delta 88.
Dolores is offline
Old November 30th, 2017, 07:29 AM
oldsmobiledave's Avatar
C heads
Thanks!
1967 Delta with a big block used a 425 with C heads.
oldsmobiledave is offline
Old November 30th, 2017, 07:47 AM
The "N" prefix on the engine unit number signifies a 1966 425 4bbl motor. At least the HEADS on your engine are from a 1966 model.
joe_padavano is offline
Old November 30th, 2017, 07:50 AM
B or C?
1966 was B heads while 1967 was C heads.
What casting letter is on your heads?
Old November 30th, 2017, 07:52 AM
Answered in Post #4
Old November 30th, 2017, 08:01 AM
thanks
Answered in Post #4
Thanks.. missed it.
Old November 30th, 2017, 09:28 AM
Dolores's Avatar
Interestingly the engine color is metallic blue - could this be a toro motor?
Dolores is offline
Old November 30th, 2017, 09:40 AM
A Toro motor would have a "T" suffix on the engine unit number. The early Toro motors are pale blue, not the 455 metallic blue.
Old November 30th, 2017, 09:49 AM
Dolores's Avatar
I’ve got a drill hole next to the fill pipe (see picture). Does this change anything?
Dolores is offline
Old November 30th, 2017, 03:43 PM
Old School Olds
tru-blue 442's Avatar
Check here on the pass. side. These are 66 B heads for a 400 442.
tru-blue 442 is online now
Old December 1st, 2017, 05:54 AM
That's SUPPOSED to be a threaded hole where the strut for the alternator bracket mounts (for non-A/C cars). If it's drilled out, someone f'd it up.
Old December 1st, 2017, 07:10 AM
Dolores's Avatar
Thanks Joe - I'd misunderstood where the famous engine drill hole was located. On closer inspection this is a threaded hole (this is an AC car and the compressor and brackets were rolling around in the trunk :-) )
Dolores is offline
RandyS
March 28th, 2013 08:25 AM
Vega
February 28th, 2012 08:27 PM
442b
February 18th, 2012 06:32 PM
young olds
August 10th, 2011 11:37 AM
mike623
February 13th, 2011 09:39 AM
Quick Reply: What Heads are these?
