What Heads are these?
Old Nov 30, 2017 | 04:38 AM
Dolores's Avatar
Just acquired a 1967 Delta 88. Carb is a Quadrajet, block stamp is 389244D. However the number stamped on the front of the passenger side head is N681957 and even though I have the FSM I can’t reconcile this number. Any ideas?
Thanks!
Old Nov 30, 2017 | 04:59 AM
cutlassefi's Avatar
Just look for the letter code on the corner of the head.
Old Nov 30, 2017 | 05:46 AM
scottv442's Avatar
Maintained
Its the engine unit number and the letter is the model line.
N is for Delta 88 I believe. See link to post below.
https://classicoldsmobile.com/forums...s-engines.html
Old Nov 30, 2017 | 07:28 AM
Dolores's Avatar
Found it - large B stamped on each head. So mine's a '66 motor in a 67 Delta 88.
Old Nov 30, 2017 | 07:29 AM
oldsmobiledave's Avatar
C heads
Thanks!
1967 Delta with a big block used a 425 with C heads.
Old Nov 30, 2017 | 07:47 AM
The "N" prefix on the engine unit number signifies a 1966 425 4bbl motor. At least the HEADS on your engine are from a 1966 model.
Old Nov 30, 2017 | 07:50 AM
B or C?
1966 was B heads while 1967 was C heads.
What casting letter is on your heads?
Old Nov 30, 2017 | 07:52 AM
Answered in Post #4
Old Nov 30, 2017 | 08:01 AM
thanks
Answered in Post #4
Thanks.. missed it.
Old Nov 30, 2017 | 09:28 AM
Dolores's Avatar
Interestingly the engine color is metallic blue - could this be a toro motor?
Old Nov 30, 2017 | 09:40 AM
A Toro motor would have a "T" suffix on the engine unit number. The early Toro motors are pale blue, not the 455 metallic blue.
Old Nov 30, 2017 | 09:49 AM
Dolores's Avatar
I’ve got a drill hole next to the fill pipe (see picture). Does this change anything?
Old Nov 30, 2017 | 03:43 PM
tru-blue 442's Avatar
Old School Olds
Check here on the pass. side. These are 66 B heads for a 400 442.
Old Dec 1, 2017 | 05:54 AM
That's SUPPOSED to be a threaded hole where the strut for the alternator bracket mounts (for non-A/C cars). If it's drilled out, someone f'd it up.
Old Dec 1, 2017 | 07:10 AM
Dolores's Avatar
Thanks Joe - I'd misunderstood where the famous engine drill hole was located. On closer inspection this is a threaded hole (this is an AC car and the compressor and brackets were rolling around in the trunk :-) )
RandyS
Mar 28, 2013 08:25 AM
Vega
Feb 28, 2012 08:27 PM
442b
Feb 18, 2012 06:32 PM
young olds
Aug 10, 2011 11:37 AM
mike623
Feb 13, 2011 09:39 AM
