Can you tell what these heads came off of?
Old August 9th, 2011, 08:05 PM
young olds's Avatar
I bought a pair of heads today and was wondering if you guys could tell me what they came off of, the guy i bought them from said they came off a 69 442. they are c heads and the numbers on the exhaust side from left to right are; cfd 16 394 548 20 on one and the other is cfd 16 394 548 332. thanks
young olds is offline
Old August 9th, 2011, 10:24 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
He's right. Those came on 68-69 motors.
J-(Chicago) is offline
Old August 9th, 2011, 11:47 PM
young olds's Avatar
Thanks. Is there any way to prove they are off a 442?
Old August 10th, 2011, 03:41 AM
Oldsdruid
rocketraider's Avatar
Big valves. Only Toronados and 442 got big-valve C's, though there are some documented 68-9 455-2 barrel engines with big-valve C's.
rocketraider is offline
Old August 10th, 2011, 09:10 AM
No. If they have small intake valves (2.000") then they did NOT come off a 442, but why do you care? All big valve C heads (used from 1967 through 1969, by the way) are the same and came on 442s, Toros, and full size cars. The only functional difference would be the pushrod holes if they came off of a motor with a 45 deg lifter bank angle. And if they were from a 67, one of the heads would have an engine unit number stamped on one end.
joe_padavano is offline
Old August 10th, 2011, 09:26 AM
young olds's Avatar
I just thought it would be cool, knowing that they were from a 442.
Old August 10th, 2011, 11:06 AM
Trying to remember member
wmachine's Avatar
The 390 HP L-32 455s that went into the Deltas had big valves too.
That best explains big valve C heads.
wmachine is offline
Old August 10th, 2011, 11:37 AM
Oldsdruid
So where you been? Thanks for clarification on the L32.
Rocket Richard
August 22nd, 2012 11:37 AM
TRW
August 29th, 2010 05:20 PM
mscofer
April 4th, 2010 06:35 PM
Atdog
January 25th, 2009 10:48 PM
shaks 442 clone
February 19th, 2008 04:51 PM
Quick Reply: Can you tell what these heads came off of?
