WHAT ENGINE?389244D
hey joe when you say don't put a lot of stock in the numbers ??were the numbers low or high, I have a chance to pick up the same motor(389244D) out of a 66 98 and wonder if its worth it? any input is greatly appreciated
The hp rating would be high by todays standards. Today all hp ratings are net with all accessories, factory exhaust, etc. When the ratings where done for 1966 it was on a dyno stand with open exhaust and no accessories. This is a simplified explaination and has been discussed many times in the fourms. Hit search and you will find lots of detail
Any 425 is worth getting, but the reason I don't put a lot of faith in the stock HP numbers is that they were biased in both directions. As noted above, early (pre-1971) motors were rated at gross HP, without stock air cleaner, manifolds, or accessories. That would normally make the ratings higher than the as-installed delivered HP. I say normally because there were some funny things going on with the highest HP engines. As an example, the 1970 W-30, with different heads, more radical cam, and O.A.I., was only rated at 5 HP more than the normal 455 (and significantly less than the Toronado 455, with a much milder cam!). A suspicious person might think that the 370 HP rating was more a function of GM's 10 lbs per HP limit (370 HP max in a 3700 lb car) than a real dyno rating.
Althow I did not do the engine build, the previous owner informed me it was stock with a W-30 cam or rated the same. I don't race the car but the HP is plenty for me. I have a buddy that has a dyno and hope to get it on next spring.
anyone have suggestions for a cam & lifters for the 425, based on the info here sounds like I have the 45 degree cam angle, veh will be driven on the street, for right now running Qjet carb,and factory dist , w30 exhaust manifolds and turbo 350 trans thx for any info
Do you think anyone here, who has photo shop could give us a preview of one?
How bout a 78/79 butlass Cutlass convertible?
79 Starfire convertible?
Any 65-88 Cutlass wagon convertible?
As long as the 1970supreme is not covering up a perv.
Jim
njot33
Sep 25, 2009 09:07 AM
