What to do with my heads
Old Jun 26, 2012 | 04:15 PM
foo's Avatar
foo
So i have "J" smog heads for my 455 should i just plan on looking for new heads in this case?
Old Jun 26, 2012 | 04:39 PM
Funkwagon455's Avatar
I would think that it would be totally dependent on your intentions with the car. If you are wanting a competitive car at the strip, well yes perhaps you would want to go in a different direction. If you are refreshing a cruiser, (which happens to have a surplus of power), then it would be all the same to continue with the J's. Let's see the subject and can go from there.
Old Jun 26, 2012 | 05:02 PM
foo's Avatar
foo
I'm going to have it as a cruiser but also would like to have it for the strip from time to time.
Old Jun 26, 2012 | 10:34 PM
64Rocket's Avatar
With the amount of money to make the "J" heads somewhat productive, you could buy these and be dollars ahead.
https://classicoldsmobile.com/forums...tar-heads.html
With amount work needed on the "J" heads as in, just doing a valve job, maybe new valves and springs to match the cam, more than likely you will need guides, plus the pocket port work and port match, you will have bunch of money in them, plus they are 40 some odd years old and heavy. You will have more money in the "J's" than what the aluminum heads cost.
just my thought.
Gene
Old Jun 27, 2012 | 03:53 AM
droptopron's Avatar
delete
I would look for heads other than J's.
Old Jun 27, 2012 | 04:04 AM
ah64pilot's Avatar
There's got to be someone looking for a boat anchor...maybe you could sell them for $5 or so?
Lol, I'm just playing. Find you a good used set of anything else and you're already ahead of where you were.
Old Jun 27, 2012 | 03:18 PM
foo's Avatar
foo
boat anchor, I was thinking the same thing lol
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
