What can I expect ?
What can I expect ?
Hey guys ... Just wondering what you guys think I should expect from some bolt on upgrades
I was running a w-30 cam with J heads , stock intake , Holley 750, and manifolds. That combo ran high 13's
I just was thinking of swapping on large valve E heads , a torker, and 1 3/4 headers with a higher 3200 stall.
Leaving the w-30 cam helps keep this a 'low' budget , and easy ...
The E heads have some minor bowl work, heat crossovers filled , .020 milled
All I have is a torker ...
U think the torker and 328 W-30 are that far off as a match ?
If this is a cam that pulls to 5500 the torker should work fine ... It's I ether that or the stock cast iron...
/224) and didnīt get impressed. Changed back to stock iron manifold and 795 Rochester. Different car, very impressed.
Stanley
1978 Oldsmobile Omega
June 15th, 2014 07:23 PM
Finn5033
October 10th, 2012 03:10 AM
IB ATEST
January 27th, 2009 12:32 PM
