What can I expect ?
Old Feb 12, 2014 | 11:25 AM
Aquaholic's Avatar
What can I expect ?
Hey guys ... Just wondering what you guys think I should expect from some bolt on upgrades
I was running a w-30 cam with J heads , stock intake , Holley 750, and manifolds. That combo ran high 13's
I just was thinking of swapping on large valve E heads , a torker, and 1 3/4 headers with a higher 3200 stall.
Leaving the w-30 cam helps keep this a 'low' budget , and easy ...
The E heads have some minor bowl work, heat crossovers filled , .020 milled
Old Feb 12, 2014 | 11:31 AM
Aquaholic's Avatar
And it is the 328 cam
Old Feb 12, 2014 | 12:09 PM
Professur's Avatar
Expect to spend a lot more on gas.
Old Feb 12, 2014 | 12:39 PM
drjr56's Avatar
Open headers and that much stall speed alone should be good for a half second at the least.....If the carbs right.
Old Feb 12, 2014 | 01:06 PM
Aquaholic's Avatar
Anyone ever run a torker / w-30 cam combo ?
I'm hoping the E heads would make the most difference
Old Feb 12, 2014 | 01:31 PM
cutlassefi's Avatar
Gear?
Old Feb 12, 2014 | 02:21 PM
Aquaholic's Avatar
3:55
Old Feb 12, 2014 | 04:20 PM
cutlassefi's Avatar
Use a Performer, not a Torker.
Old Feb 12, 2014 | 04:43 PM
Aquaholic's Avatar
All I have is a torker ...
U think the torker and 328 W-30 are that far off as a match ?
If this is a cam that pulls to 5500 the torker should work fine ... It's I ether that or the stock cast iron...
Old Feb 12, 2014 | 04:48 PM
cutlassefi's Avatar
Sell it or exchange it for a Performer.
Jmo.
Old Feb 13, 2014 | 09:47 AM
455man's Avatar
I could see you breaking into the high 12's if everything is tuned right. What car is this in?
Old Feb 13, 2014 | 11:41 AM
Aquaholic's Avatar
I have a 66 cutlass ...
Doing the engine swap in April ...
I picked up a cheap torker and want to try a single plane. I'm really curious to see how this motor will respond to the changes ...
Old Feb 13, 2014 | 11:42 AM
Aquaholic's Avatar
Pic is on my profile
Old Feb 13, 2014 | 11:54 AM
72cuttys's Avatar
Got a torker manifold for sale if your looking.
Old Feb 13, 2014 | 12:46 PM
Aquaholic's Avatar
Why are u getting rid of it ?
What was your experience with it ?
Old Feb 13, 2014 | 12:51 PM
Aquaholic's Avatar
C
Old Feb 13, 2014 | 12:52 PM
Aquaholic's Avatar
There must be someone that threw a torker and headers on their 442 ...
Old Feb 13, 2014 | 01:15 PM
72cuttys's Avatar
I didnt run it, it came on a 455 i bought to rebuild. I am getting rid of it because im not fond of edelbrock carbs, so I am swapping to a square bore holley and need a manifold to match.
Old Feb 17, 2014 | 07:46 AM
Oldwolf's Avatar
I put a torker and a Holley 750 on my 455 with speed pro 2323 pistons E heads and comp cam, Magnum (270
/224) and didnīt get impressed. Changed back to stock iron manifold and 795 Rochester. Different car, very impressed.
Stanley
1978 Oldsmobile Omega
Jun 15, 2014 07:23 PM
350RocketSBO
Jun 16, 2013 03:25 PM
Finn5033
Oct 10, 2012 03:10 AM
bobb
Brakes/Hydraulic Systems
Oct 10, 2010 12:03 PM
IB ATEST
Jan 27, 2009 12:32 PM
