went HEI
Old September 11th, 2010 | 10:05 PM
1973olds98's Avatar
went HEI
i changed my dist. to hei,,,,When i go get plugs they do not offer hei plug wires for my year,,would plug wires for a 1974 olds 98 with hei work for my 1973 olds 98..
Old September 11th, 2010 | 10:17 PM
Shizzy's Avatar
yup, just get them for any olds V8 that came with HEI.
Old September 11th, 2010 | 10:35 PM
svnt442's Avatar
Now you kinda have to be careful with that. They moved #1 in a couple of the books I have seen and that will change the layout of the wire lengths. Personally I prefer to cut my own wires to length. It takes a bit more time, but makes for a lot neater under hood.
I would just re-gap your spark plugs to .045 and be done with it. Olds was experimenting with HUGE gaps and all they do is stress the coil unduly.
Old September 12th, 2010 | 12:27 AM
64Rocket's Avatar
I thought '73 was the first year for the "HEI".
Gene
Old September 12th, 2010 | 06:53 AM
MrRocket's Avatar
MasterDaddy
I thought it was optional in 74 and standard in 75.
Old September 12th, 2010 | 08:04 AM
cutlassefi's Avatar
My dad had a 4 door Cutlass Supreme for a company car when I was a kid. It had a 350 4bl with regular points, ran real lean and consequently ran horribly. Then he had a 75 Caprice with a 400 and HEI, I remember that car running o.k.
Last edited by Olds64; September 13th, 2010 at 07:00 AM. Reason: no cussing please
Old September 12th, 2010 | 09:21 AM
redoldsman's Avatar
Proud Viet Nam Veteran
X2. That would be correct. HEI came standard the same year we got catalytic converters.
Old September 12th, 2010 | 09:09 PM
1973olds98's Avatar
so the gap should be .045 for a HEI set=up
Old September 12th, 2010 | 09:10 PM
1973olds98's Avatar
If a set of plugs wires for a 74 dont work i will buy a custom set..
Old September 13th, 2010 | 07:01 AM
Plug wires for a 74 should work fine.
joepenoso
June 11th, 2014 05:48 PM
joepenoso
June 4th, 2014 02:56 PM
oldscruiser
February 15th, 2011 01:44 AM
veltboy618
March 30th, 2009 05:30 AM
blkmonday
November 7th, 2008 10:13 PM
