Water Pump Question
Water Pump Question
Hello! I have a 1969 Oldsmobile 455 (39M181457 - no AC installed). I want to replace the water pump with a high volume pump. I initially looked at the aluminum FlowKooler 1775 pump but I see it is for 1971 Olds 455s and above. I thought this was odd because it seems most parts for the Olds 455s from the late 60s to the early 70s are interchangeable.
I plan on installing a March Performance Ultra Style Serpentine Belt Conversion Kit (part #16065) so I know I need a 6 long pump. Will the aluminum 1775 fit my 1969 motor?
Im asking because the March Performance kit requires a 6 pump and the FlowKooler pumps for the 1969 are 5 5/8 rather than 6. Anyone have any information or recommendations on what water pump I should use on my 1969 with a MP serpentine belt kit? I would like to go aluminum and high volume but will go with whatever it takes.
Thanks!!
Ray
Thanks!!
Ray
Thanks!!
Ray
Thanks!!
Ray
As for the "serpentine" conversion, you are aware, I assume, that the March kit isn't really a serpentine design, since it does not use a reverse rotation pump. It's your money, but that's a lot of change for no performance benefits.
And if you do decide to keep the shorter pump, that would be Flowkooler 1776.
Nor Cal Andy
March 29th, 2012 07:27 PM
