Water Pump Question
Old Oct 26, 2012 | 12:28 AM
1970Olds442's Avatar
Water Pump Question
Hello! I have a 1969 Oldsmobile 455 (39M181457 - no AC installed). I want to replace the water pump with a high volume pump. I initially looked at the aluminum FlowKooler 1775 pump but I see it is for 1971 Olds 455’s and above. I thought this was odd because it seems most parts for the Olds 455’s from the late 60’s to the early 70’s are interchangeable.
I plan on installing a March Performance Ultra Style Serpentine Belt Conversion Kit (part #16065) so I know I need a 6” ‘long’ pump. Will the aluminum 1775 fit my 1969 motor?
I’m asking because the March Performance kit requires a 6” pump and the FlowKooler pumps for the 1969 are 5 5/8” rather than 6”. Anyone have any information or recommendations on what water pump I should use on my 1969 with a MP serpentine belt kit? I would like to go aluminum and high volume but will go with whatever it takes.
Thanks!!
Ray
Old Oct 26, 2012 | 06:47 AM
Thanks!!
Ray
The only difference between the 1970-earlier and the 71-later pumps is the diameter of the pump inlet. Just get the lower radiator hose that matches the pump.
As for the "serpentine" conversion, you are aware, I assume, that the March kit isn't really a serpentine design, since it does not use a reverse rotation pump. It's your money, but that's a lot of change for no performance benefits.
And if you do decide to keep the shorter pump, that would be Flowkooler 1776.
jpc647
May 27, 2024 10:13 AM
texasred
Oct 21, 2016 09:43 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
jpc647
Jun 15, 2009 07:49 AM
