Valve stem height
Valve stem height
can anyone that has the tool (BT-6428) for measuring the valve stem height on the heads tell me the measurement with the tool on a piece of glass from the area where you measure to the bottom of the glass.
I can but it might not do what you need. The tool's surface which is above the valve stem (about 7/16" x 7/16") is not parallel with the surface of the glass due to the angle of the valve in the head as compared to the line between the machined cover rests. I couldn't find my set of standards, but the (unverified) micrometer indicates about 1.234" on the side closest to the close leg and 1.197" on the other side. The centerline of the surface which is above the valve is about 1-3/16" from the centerline of the near leg. Before fabrication those micrometer values should be checked.
Last edited by Ozzie; April 13th, 2016 at 09:40 PM. Reason: reword sentences for clarification
thanks
I can but it might not do what you need. The surface which contacts the valve stem (about 7/16" x 7/16") is not parallel with the surface of the glass due to the angle of the valve in the head as compared to the line between the machined cover rests. I couldn't find my set of standards, but the (unverified) micrometer indicates about 1.234" on the side closest to the close leg and 1.197" on the other side. The centerline of the surface which contacts the valve is about 1-3/16" from the centerline of the near leg. Before fabrication those micrometer values should be checked.
thanks again ray
In the 67 Chassis manual, engine section, there is a reference picture that might give you the information you are looking for.
Look on OLDSMOBILITY.com web site. The info might be there also.
Almond900
February 26th, 2016 02:56 AM
