Valve stem height
Old Apr 12, 2016 | 09:57 AM
NDERISE's Avatar
Valve stem height
can anyone that has the tool (BT-6428) for measuring the valve stem height on the heads tell me the measurement with the tool on a piece of glass from the area where you measure to the bottom of the glass.
Old Apr 12, 2016 | 04:47 PM
Ozzie's Avatar
I can but it might not do what you need. The tool's surface which is above the valve stem (about 7/16" x 7/16") is not parallel with the surface of the glass due to the angle of the valve in the head as compared to the line between the machined cover rests. I couldn't find my set of standards, but the (unverified) micrometer indicates about 1.234" on the side closest to the close leg and 1.197" on the other side. The centerline of the surface which is above the valve is about 1-3/16" from the centerline of the near leg. Before fabrication those micrometer values should be checked.
Last edited by Ozzie; Apr 13, 2016 at 09:40 PM. Reason: reword sentences for clarification
Old Apr 13, 2016 | 09:40 AM
NDERISE's Avatar
thanks
Originally Posted by Ozzie
I can but it might not do what you need. The surface which contacts the valve stem (about 7/16" x 7/16") is not parallel with the surface of the glass due to the angle of the valve in the head as compared to the line between the machined cover rests. I couldn't find my set of standards, but the (unverified) micrometer indicates about 1.234" on the side closest to the close leg and 1.197" on the other side. The centerline of the surface which contacts the valve is about 1-3/16" from the centerline of the near leg. Before fabrication those micrometer values should be checked.
thanks a million for your reply Ozzie I forgot that the valves r on an angle which would make it difficult to get a measurement, I really appreciate your efforts to try to give me the info. that u did. I'm sure there is a way to take a measurement using the degree of the valve to figure it out, just not sure how to do it.
thanks again ray
Old Apr 13, 2016 | 07:46 PM
edzolz's Avatar
In the 67 Chassis manual, engine section, there is a reference picture that might give you the information you are looking for.
Look on OLDSMOBILITY.com web site. The info might be there also.
esisson
Jun 7, 2023 07:44 AM
Almond900
Feb 26, 2016 02:56 AM
jag1886
Dec 18, 2013 03:43 AM
jensenracing77
Mar 22, 2013 06:57 AM
Half Baked
Jan 10, 2008 08:43 PM
