Valve stem height
Valve stem height
can anyone that has the tool (BT-6428) for measuring the valve stem height on the heads tell me the measurement with the tool on a piece of glass from the area where you measure to the bottom of the glass.
Last edited by Ozzie; Apr 13, 2016 at 09:40 PM. Reason: reword sentences for clarification
thanks
I can but it might not do what you need. The surface which contacts the valve stem (about 7/16" x 7/16") is not parallel with the surface of the glass due to the angle of the valve in the head as compared to the line between the machined cover rests. I couldn't find my set of standards, but the (unverified) micrometer indicates about 1.234" on the side closest to the close leg and 1.197" on the other side. The centerline of the surface which contacts the valve is about 1-3/16" from the centerline of the near leg. Before fabrication those micrometer values should be checked.
thanks again ray
Almond900
Feb 26, 2016 02:56 AM
