Which Valve Covers and oil fill tube for '68 442 400 4V
I'm still trying to sort all of the parts I got with this new project. I have 4 different sets of valve covers. The first set is flat without oldsmobile on them. The second set is flat on driver and notched(for a/c?) on passenger without oldsmobile on either one. The next set is same notched blank cover on passenger and flat with oldsmobile on the driver cover. The next set is both with oldsmobile on them. Also, I got a set of M/T covers...old but good castings. If it matters, I have the "C" heads.
Which covers would be correct for a 68 400 without A/C?
I also have 2 different oil fill tubes. One is red and one is black. Which one is the original?
I've attached some photos after I brought her home today. I power washed the mold and clear coat off before coming home! For a "city" find she is not in too bad of shap.
Welcome to the site! All 1968-72 442's got the notched valve covers on both sides, even if the cars came without AC and power brakes. Would you post pictures of the oil fill tube? There were a couple different designs, but the best way is for us to see what you have.
If you want to post the extra valve covers in the parts for sale section there's a good demand for the M/T covers, the ones with Oldsmobile pressed into the metal, and the stray notched cover. It sounds like you need a drivers side notched cover, correct? You can make a post for that in the parts wanted forum. John
The number on the oil fill tube is the engine unit number. Olds started putting engine unit numbers on the oil fill tube of all Olds V8 engines in 1968. Before that, the engine unit number was stamped on the front of the right side cylinder head.
If your 400 is a '68 engine, there should be an engine unit number stamped on the oil fill tube that starts with an 8. My guess is that, if the red tube starts with a 4 and there is no number on the black tube, neither is original to your '68 400.
The oil fill tube was straight on all '68-'72 Olds V8 engines, except for '68 models with A/C, which used a tube with a 30 degree angle.
Randy C.
Randy C.
Whoops! I just noticed the casting letter after the string of numbers to the right of the fill tube. It looks like an F block, correct? That would be a 455 engine. Only the Hurst Olds got a 455 in 1968, so the correct 400 engine would have a large letter G after the string of numbers.
By the way, I don't know what it looked like before you washed it off but the car in the pictures looks very nice! John
Do I paint it bronze or black? While on the subject which engine paint do you recommend? I will also need the orange/red for the air cleaner.
Check em out!
https://classicoldsmobile.com/forums...-455-4spd.html - this thread has a picture of it after I uncovered it and my Novas
https://classicoldsmobile.com/forums...ower-tour.html - this thread has some pre-cleaning pictures
https://classicoldsmobile.com/forums...tml#post383631 - this thread has my body tag that needs some decoding
FYI, you don't have four sets of valve covers. You have eight unmatched valve covers. The OLDSMOBILE lettered valve covers were only used in the 1973-74 model years. The 68 442 should have a pair of notched covers, and in both cases the notches go towards the rear of the engine.
Im still hunting for the exhaust manifolds.
Wow! It sounds like this guy has a serious collection. Would love to have a set of D heads myself, but agree its better to sleep well at night. Sorry, I had missed your previous post about the engine missing.
Bronze would be the correct color for your car. You can use the search option to try and find threads with pictures of different brands. Here's a recent thread that discusses both gold and bronze colors from different vendors and opinions of what looked good.
https://classicoldsmobile.com/forums...ine-paint.html
I also found the original spare, jack,and chrome dealer emblem(Jack Schmid Columbus Ohio) in the trunk. Im trying to get him to give me some copies of photos of the cars original paint. He is also going to give me as much information about the history as he can. I lucked out on this deal; it is the best I've come accross yet.
69442murph
March 21st, 2013 09:09 AM
