Valve covers leaking like crazy
Old Apr 21, 2024 | 07:49 PM
JAXX455's Avatar
72 cutlass 455 drivers side rear bottom corner bolt closest to the windshield looks like where the leak is coming from. Hard to really tell.
replaced with new edelbrock chrome valve cover and using rubber gasket. Have removed and replaced gasket 3 times & still no luck.
any ideas?
do I need different valve covers?
Edelbrock chrome valve covers known for leaking?
should I try cork?
leakin bad, any need help would gladly be appreciated.
would anything else in this area leak oil?
leaking down on the headers and smoking like crazy when I drive.
thanks!
Old Apr 21, 2024 | 07:51 PM
From all I have read, yes.
Old Apr 21, 2024 | 08:01 PM
v8al's Avatar
Registered Olds Owner
Buy the good valve gaskets from Bernard Mondello Racing Enterprises. (not Mondello Performance of Paso Robles) Also make sure your valve covers are flat.
If you find another source for these gaskets let me know.
See this post: Best valve cover gaskets?
Old Apr 21, 2024 | 08:42 PM
I prefer cork myself. I use weather strip cement and glue them to the valve cove and dry against the head.
Old Apr 21, 2024 | 08:52 PM
v8al's Avatar
The ones I am referring too are reusable, you can't over torque them and don't require sealer.
Old Apr 21, 2024 | 09:35 PM
JAXX455's Avatar
Those look nice! I’m gunna place an order tomorrow! Thanks!
Old Apr 22, 2024 | 08:52 AM
JAXX455's Avatar
What valve covers are having the best fit?
Aluminum heads 455.
What has worked well for you guys?
Would prefer in chrome finish.
Thanks.
Old Apr 22, 2024 | 10:23 AM
JAXX455's Avatar
Where can I order these?
I'm on the website but no items listed?
Any ideas?
Thanks.
Old Apr 22, 2024 | 10:41 AM
v8al's Avatar
@JAXX455 Bernard is old school - you have to call him.
Old Apr 22, 2024 | 10:43 AM
JAXX455's Avatar
Roger that.
Old Apr 22, 2024 | 02:05 PM
cutlassefi's Avatar
Mahle VS 50971? I think? I’ll double check and let you know.
Old Apr 22, 2024 | 04:28 PM
I saw these on the local Craigslist:
https://phoenix.craigslist.org/evl/p...737310219.html
Old Apr 22, 2024 | 05:48 PM
oldsrush's Avatar
Gearhead
These are the best out there, extra thick and steel core and no need to apply adhesive. Priced great
Speedmaster® Valve Cover Gasket PCE353.1023 | Buy Direct with Fast Shipping (speedmaster79.com)
Old Apr 23, 2024 | 05:54 AM
jensenracing77's Avatar
That is what I have been doing for a few years now. I did just find out that if you wipe baby powder on the head side of the gasket, it will not stick and not leak on that side if you want to reuse them next time. I am going to try that next time.
Old Apr 23, 2024 | 02:36 PM
v8al's Avatar
I agree 100% with you guys - this is pretty much the procedure I had been doing. (minus the baby powder) If you are not taking off your valve covers frequently this is the good approach and at a reasonable cost.
If however you take your valve covers off with any frequency the better gaskets will make it so much easier. The main advantages I see is that you don't have to worry about over torquing the gasket and they should last a long long time.
Old Apr 24, 2024 | 01:46 PM
JAXX455's Avatar
Just got off the phone with him. He was extremely helpful and knowledgeable on his products. Great guy. Placed order and wanted to order a pair of his valve covers too but he say's they no longer make em. Too bad, those things are BAD ***!
Thanks for the info and recommendation, I'll report back once I receive these gaskets and get em installed. Hopefully it solves my oil leak issue.
Thanks again!
NTXOlds
Jul 10, 2021 03:19 PM
Darkalley
Jun 5, 2021 11:04 AM
williamwallace11
Apr 5, 2021 06:42 AM
slantflat
Apr 26, 2013 04:15 AM
Destructor
May 12, 2010 09:05 AM
