Valve Cover Spacers
Old Jan 25, 2022 | 01:42 PM
AK71CutlassS's Avatar
Valve Cover Spacers
All,
got some info from Joe P. but looking for some 3/8 inch valve cover spacers. They seem to be kinda expensive. I know I can double gasket but seems like they might be more likely to leak.
I have a 11 inch booster M/T Valve covers.
HS rockers with short polys.
will they fit with the spacers W/ The 11 booster. ?
Old Jan 25, 2022 | 02:48 PM
oldsrock's Avatar
I had that combination for a while, it clears the booster.
Old Jan 25, 2022 | 02:58 PM
70W-32's Avatar
Check Ebay for the spacers, or
Rocket Racing 3/8 $119
Ram Air Restorations $109
Old Jan 25, 2022 | 10:29 PM
I use to double gasket the valve covers, it seems the gaskets eventually crush down to the point they don’t provide the clearance needed anymore, or started to seep oil. I put spacers on probably 10 years ago, I haven’t touched them since.
Old Jan 25, 2022 | 10:37 PM
you silicone spacers to head then gasket?
Old Jan 26, 2022 | 03:33 AM
Gasket, spacer, another gasket, then the valve cover.
I bought some 1/4x18 (1 1/4 long I think?) studs with Allen socket holes, screwed those into the heads, and used flange nuts with knurled heads. The studs make it easy to keep everything lined up during assembly, the knurled flange nuts make sure the nuts don’t come loose.
Old Jan 26, 2022 | 07:11 AM
oddball's Avatar
I silicone the spacer to the valve cover, then just use a gasket normally.
Ram Air is good guys, ship quick.
Rocket Racing is awesome, but getting them to process and ship sometimes happens in a day, sometimes in .... a lot more.
65Blu442
Apr 29, 2021 01:13 PM
AK71CutlassS
Apr 26, 2017 11:51 AM
Almond900
Feb 26, 2016 02:56 AM
blackbird51
Jul 10, 2013 11:29 AM
Dapper 1956
Feb 10, 2011 08:00 PM
