vacuum lines
Not much to it really
See the Chassis Service Manual available for free via
wildaboutcars.com
carb or manifold to distributor.
IF you want/ need it then the Thermal Vacuum Switch on the intake is labelled
D distributor
C Carb
MT manifold tap.
Big one to power brakes if applicable.
Bigger one to PCV in LH valve cover.
One MT to auto trans if applicable
that's about it.
wildaboutcars.com
D distributor
C Carb
MT manifold tap.
that's about it.
