vacuum lines
Old Oct 16, 2013 | 09:14 AM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
vacuum lines
need a vacuum lines diagram for a 69 442 ( big block )...thanks
Old Oct 16, 2013 | 09:54 AM
Octania's Avatar
Not much to it really
See the Chassis Service Manual available for free via
wildaboutcars.com
carb or manifold to distributor.
IF you want/ need it then the Thermal Vacuum Switch on the intake is labelled
D distributor
C Carb
MT manifold tap.
Big one to power brakes if applicable.
Bigger one to PCV in LH valve cover.
One MT to auto trans if applicable
that's about it.
Old Oct 16, 2013 | 06:10 PM
knighthawk's Avatar
yeah BUT ,,,,,there are 3 manifold fittings to the rear of the carb ????
I/4 '' lines
Old Oct 16, 2013 | 06:34 PM
  1. A/C system
  2. Air cleaner valve
  3. Transmission modulator
There really aren't very many lines.
Old Oct 17, 2013 | 03:10 AM
Yellowstatue's Avatar
And the one rear fitting is for the pwr brks...
StarfireFox62
Sep 25, 2008 01:29 PM
#1CutlassSupreme
May 14, 2008 04:28 PM
terribleonexx88
Mar 16, 2007 12:00 PM
Chumley
Jan 3, 2007 06:00 AM
bbock
Jun 5, 2006 11:50 AM
