Vacuum lines on 67 Cutlass 442
Old Apr 12, 2019 | 06:43 PM
Rocket Olds's Avatar
Got '67 4-4-2 and vacuum lines were all a mess and I am trying to put back correctly. It has correct q-jet and I see 4 ports on the front of the carb. I know the big one goes to the PCV valve on valve cover. I see the one for the choke pull-off. But where does the vacuum advance hose attach? To the 3/16" port or to the 1/4"? but then what goes to the remaining port once the advance is hooked up? The brake booster and the reservoir ball at firewall are each connected to the manifold. it has no A/C. It has open round air cleaner not snorkel type. It does have trunk release button in glove box and it gets it vacuum from that ball at firewall and the release works fine after fixing the hose under rear seat. Thanks
Old Apr 12, 2019 | 08:19 PM
2blu442's Avatar
This may or may not be correct for your 442 with a 400 engine, but its a place to start. Hopefully its close enough that others can work off these photos and tell you the correct locations. This is on a survivor car with low miles, at least it was until I let it sit and clearly the mice and spiders have moved in! Its a 1967 4 door with a 330 4bbl and automatic transmission.
These first two photos are an overview of the front of the carburetor.
Old Apr 12, 2019 | 08:23 PM
2blu442's Avatar
This line goes to the distributor vacuum advance. I just barely got my fingertips in the photo.
This bottom line goes to the transmission, you can see the metal line its attached to
Old Apr 12, 2019 | 11:29 PM
Hairy Olds's Avatar
Shoveling Snow
Untouched low mile 67 442
Old Apr 13, 2019 | 06:13 AM
The correct vacuum hose routing depends on trans, equipment, and CA or non-CA emissions. The factory Chassis Service Manual shows ALL the routing options. Read it.
Old Apr 13, 2019 | 12:01 PM
Thanks to 2blu442, Hairy, and Joe for your help, you have answered my questions.
ej69
Apr 26, 2018 08:03 AM
frdebelo
Feb 2, 2018 10:49 AM
yankees
Sep 24, 2012 03:08 PM
pogo69
Hurst/Olds
Apr 3, 2011 11:03 AM
Flye
Apr 19, 2009 06:33 AM
