69H/O air cleaner vacuum line
Old Apr 1, 2011 | 06:06 AM
pogo69's Avatar
morgan
hello folks...looking for some help on 69 H/O resto... the vacuum line from the flapper door motor, where does this hose connect too? also should my intake manifold have a 3 ported vacuum switch?
thanks
Old Apr 1, 2011 | 07:05 AM
1969Hurst's Avatar
Should connect via a hose 'T' to the line that runs from the intake manifold to the vacuum bulb on the firewall. Looking down on the engine you will have 3 vacuum fittings behind the carb on the intake. 1st one should lead to the air cleaner snorkle, 2nd one to the bulb, last one for brake vacuum.
Yes, you should have a 3 ported vacuum switch. Top port to distributor, middle to carb, bottom to hose 'T' for line leading to Trans Vac.
thanks
Old Apr 2, 2011 | 07:37 PM
pogo69's Avatar
morgan
Did the non A/C have the ball?...mine does not have the ball but there is a small Tee right behind the carb.
Old Apr 3, 2011 | 11:03 AM
69HO43's Avatar
The three ported vacuum switch on the intake goes four places. Top port to the distributor, bottom one to the intake vacuum (and auto trans modulator via a Tee), and middle one to the carb.
IIRC, the intake fitting behind the carb goes to the air cleaner Thermac control which has a Tee in it for the flapper vacuum. And if you have a ball on the firewall (A/C and/or trunk release) it Tees off that line.
You don't absolutely need the switch, but it helps with overheating control to an extent.
1965cutlassragtop
Jul 15, 2012 06:26 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
Steve Wike
Oct 26, 2010 06:35 AM
fizzy55
Hurst/Olds
Jan 14, 2009 04:58 AM
Chumley
Jan 3, 2007 06:00 AM
