Throttle Shaft Bushings
Old Nov 29, 2016 | 08:28 AM
67Rocket's Avatar
Have any of you guys attempted to replace the throttle shaft bushings on Quadrajet carbs.? Any help/tips would be appreciated.
Old Nov 29, 2016 | 10:29 AM
RetroRanger's Avatar
72 Olds CS
I'll subscribe I've got a nice clean carb that needs bushings..
Old Nov 29, 2016 | 10:39 AM
don71's Avatar
same but different
Its been some years for me.
I purchased a kit from summit under the JET brand. The kit contained some bushings and a reamer. Enough to do several carbs.
The hard part for me was removing the throttle blades from the shaft. Those little screws are staked in and can break. I believe I ground the end of the screw off before removing. I sourced the small screws somewhere? after breaking a couple of them.
Old Nov 29, 2016 | 11:15 AM
Yup. This is the trick. Just remember to re-stake the screws after reassembly to avoid sucking one into the engine.
Old Nov 29, 2016 | 12:15 PM
don71's Avatar
same but different
You tube has a few videos of this process. This poster does a good job showing you and lists part numbers from mcmaster carr. The following links are 1 and 2 of 3 videos.
Old Nov 29, 2016 | 02:08 PM
Great info. I need to do this on my spare carb.
Old Nov 29, 2016 | 02:13 PM
ELY442's Avatar
I bought my kit from www.quadrajetparts.com. Very easy kit to use.
Old Nov 29, 2016 | 02:27 PM
67Rocket's Avatar
Thanks, very helpful
Old Jan 9, 2017 | 02:16 PM
442fanatic's Avatar
I have a kit with the drill, some extra bushings and such if you want.
I replaced them on one of my carbs.
Not a bad job to do, as long as that is the only thing wrong with the carb. My carb turned out also to have issues with crap stuck in the little passages.
Old Jan 9, 2017 | 03:25 PM
Gary M's Avatar
I had to use a drill press with a good vise. If the drilling is not straight the shaft will bind enough to make it hard to operate. Staking as advised above is a must.
Old Jan 10, 2017 | 06:19 AM
67Rocket's Avatar
Thanks, I had mine done by Quadrapower in Texas.
Old Jan 10, 2017 | 06:25 AM
67Rocket's Avatar
That should be Quadrajet Power. Looks like a good job, haven't installed carb yet.
Old Jan 10, 2017 | 11:11 AM
oldolds88's Avatar
be careful not to press the bushings in to hard,sometimes it will split the base plate
Oldssupreme
Aug 19, 2016 09:36 AM
rothlane'68
Nov 29, 2015 06:54 PM
dancutlass
Aug 21, 2012 06:26 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
Slick68
Oct 25, 2010 08:13 PM
