Stretched belts?🤔
Old Mar 4, 2022 | 03:50 AM
  #41
72455's Avatar
1972 U code Supreme
I guess your confusion is the sequence of tightening the bolts?? I interpreted your question as the order of tightening the belts.
Technically, it doesn’t matter the sequence you tighten the power steering pump hardware. Having said that, unless your REALLY flexible, or have some assistance, it will be pretty difficult to hold the pump in position to tension the belt, while simultaneously reaching under or behind the pump to tighten those bolts.
Ok..so let me dig this ditch a little deeper. While I understand the logic, what I don't understand is the technical. How do all three fasteners play a role in setting and maintaining the proper tension on the p/s belt?
Old Mar 4, 2022 | 07:17 AM
  #42
Achcoastal's Avatar
I don’t know where your location is but up here in New England, especially with my twin inboard boat I would have squealing belts come springtime. The boat would lay up in my yard for winter and the cold would contract the belts tight against the pulleys and stretch them out. And quite a bit too. Solution was after winterizing the engines in the fall, loosen the belts during layup. Of course this is a moot point if your garage is heated or your in warm climates
Old Mar 4, 2022 | 10:11 AM
  #43
sysmg's Avatar
I think the confusion is in AC cars where alternator and power steering pump is on the same side of the engine. In that case you have to tighten the one with two belts, before the other one (only getting one dedicated belt tight) then adjust the one with one belt, which will tighten it around both.
As far as tightening the three bolts on the power steering pump, the most important one to tighten first is the one in the adjusting slot. However in some cases the power steering pump could be at an angle and tightening the other bolts will straighten it out, thus either making the belt loose or too tight.
mefirst72
Apr 10, 2014 10:09 AM
Winger67
Nov 24, 2013 02:39 PM
at3reg98
Nov 7, 2012 04:59 AM
kplange
Jan 7, 2012 07:11 PM
WasteOfMind00
Apr 12, 2007 06:38 AM
