sportsman roller tip rockers
Would these be suitable/advantageous for a mildly modded 425 66 toro engine ?
Has anyone used these maybe ?
thanks mike
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
thanks mike
First off you will need to run diffrent pushrods,You will also need studs instead of the stock type bolts and guide plates, I have run the comp Cams kit with succuss and it comes in a complete "Kit" for BBO Or SBO I would avoid those and go with the kit my $.02,I have run these with a .500 lift cam and as fast as low 12's..............Jerr
See kit here > http://cgi.ebay.com/ebaymotors/Comp-...91710004r12974
![](http://a763.g.akamai.net/7/763/1644/42/app.infopia.com/img/image/fp/VPID/5803907/img42/img.jpg)
May I pick your brains a little more please
It transpires that comp cams does not make a kit for the 425 . 455 ,350 etc yes .{ email from jegs tech dept)They (comp cams ) do however, supply the roller rockers to suit . 1442-16 # from memory.
Any geometry hassles with going for these alone ????--guide plates, rods which I own are in good nick .![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
thanks
mike
thanks
mike
see the bottom of the page at this link for the Oldsmobile roller rocker kits
http://www.compcams.com/information/...gnumRoller.asp
sxsleeper
March 20th, 2021 02:45 PM
