sportsman roller tip rockers
Old Sep 11, 2009 | 07:39 PM
geckonz08's Avatar
Would these be suitable/advantageous for a mildly modded 425 66 toro engine ?
Has anyone used these maybe ?
thanks mike
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Sep 11, 2009 | 08:09 PM
cutlassefi's Avatar
Rockers
Not that it really matters but the first question I'd ask is are they 1.65 or 1.6? Read the add, it says both. Hmmmmm...
Old Sep 11, 2009 | 08:40 PM
geckonz08's Avatar
cutlass ,
1.65 is how I read it -
Old Sep 11, 2009 | 08:49 PM
jims2000lt's Avatar
11.52 @116
I would figure that they would help with less with less vavletrain stress and you may see a few HP to. Gotta be an upgrade over stock ones.
Old Sep 11, 2009 | 09:28 PM
BIGJERR's Avatar
I bleed Oldsmobile
First off you will need to run diffrent pushrods,You will also need studs instead of the stock type bolts and guide plates, I have run the comp Cams kit with succuss and it comes in a complete "Kit" for BBO Or SBO I would avoid those and go with the kit my $.02,I have run these with a .500 lift cam and as fast as low 12's..............Jerr
See kit here > http://cgi.ebay.com/ebaymotors/Comp-...91710004r12974
Old Sep 12, 2009 | 05:24 AM
jensenracing77's Avatar
X2
Old Sep 12, 2009 | 07:38 AM
citcapp's Avatar
X3 The kit is the way to go. If you buy the cheap stuff then you have to piece meal the whole thing
Old Sep 14, 2009 | 12:12 PM
geckonz08's Avatar
thanks guys --very useful info --will get onto the kit
Old Oct 6, 2009 | 11:55 AM
geckonz08's Avatar
May I pick your brains a little more please
It transpires that comp cams does not make a kit for the 425 . 455 ,350 etc yes .{ email from jegs tech dept)They (comp cams ) do however, supply the roller rockers to suit . 1442-16 # from memory.
Any geometry hassles with going for these alone ????--guide plates, rods which I own are in good nick .
thanks
mike
Old Oct 6, 2009 | 12:48 PM
citcapp's Avatar
see the bottom of the page at this link for the Oldsmobile roller rocker kits
http://www.compcams.com/information/...gnumRoller.asp
Old Oct 9, 2009 | 05:01 PM
coltsneckbob's Avatar
I heard that these roller rockers can be noisy. They sound like tapping valves.
sxsleeper
Mar 20, 2021 02:45 PM
tomngary
Sep 18, 2013 05:22 PM
tomngary
Aug 20, 2013 09:34 AM
RAMBOW
Jan 26, 2013 10:43 PM
Chesrown 67 OAI
Jun 22, 2011 06:03 AM
