size of vacuum hoses 1970 Toro
Old June 29th, 2011, 03:23 AM
EightballZ's Avatar
hi guys,
i'm planning to completly overhaul the vacuum system on my toro (cruise control, brake booster and every other hose coming out of the intake manifold)
i got the manual with the vacuum hose routing..thats not the problem..but i cant find the sizes i need to use...like the diameter...the length is not that important...but the diameter is. so do u guys have any idea..or something like an overview?
i'm many miles away from my car..so i cant meassure myself...but i need to order them quickly.
thy and bye
EightballZ is offline
Old June 29th, 2011, 06:00 AM
Tony72Cutlass'S''s Avatar
I'm gonna go with 1/8'' fuel line, that's what i used, make sure 1/8'' is stamped on it, because i believe that's the inner size of the tube, not the actual diameter of the rubber stuff.
You might also wanna pick up some 3/8'' fuel line for the rest of it.
Not sure if you have PCV on your toronado, but that's all 3/8's on my car (72) but if you havn't replaced your fuel line for awhile and you're already cutting tubes, may as well to avoid future issues.
-Tony
Tony72Cutlass'S' is offline
Old July 4th, 2011, 01:38 AM
EightballZ's Avatar
ok thx...i'll try
cutlass47
March 30th, 2017 09:41 AM
orman_s
September 22nd, 2013 02:27 PM
zodiacblueS
September 26th, 2011 07:25 AM
deaddds
January 25th, 2010 06:40 PM
7244too
March 5th, 2009 02:55 PM
Quick Reply: size of vacuum hoses 1970 Toro
