roller rocker arm choices
Old Dec 10, 2014 | 09:38 PM
72cuttys's Avatar
I understand that the 5016 Harland Sharp's are the bee's knees, but what other options out there maintain the proper geometry for the olds 455? If the HS are obviously the best choice, I will fork out the cash BUT if there is a similar rocker arm in a more economical price range I'd rather go for that.
Old Dec 11, 2014 | 04:43 AM
cutlassefi's Avatar
5016's are for Edelbrock heads. They are .050 longer on the valve side for the longer Edelbrock valves.
For a stock head you can use any quality Ford small block rocker.
Old Dec 11, 2014 | 04:56 AM
brownbomber77's Avatar
Wait, I asked this question before and didn't get an answer, but will the Crane pedestal ones work in that case? The ones that came stock on the 93-95 Mustang Cobras.
http://www.summitracing.com/parts/cr...6-16/overview/
https://classicoldsmobile.com/forums...ckers-fit.html
Old Dec 11, 2014 | 05:19 AM
72cuttys's Avatar
I was planning on running a set of Smitty pro-comps. Same thing?
Old Dec 11, 2014 | 05:39 PM
cutlassefi's Avatar
Yes or you can use the Pontiac/Ford stuff. I used a set of aftermarket Pontiac 1.65 Steel rollers on Edins 455. Valve stem contact was perfect.
Old Dec 27, 2014 | 02:00 PM
naphtali5725's Avatar
what brand rockers are those?
Old Dec 31, 2014 | 06:24 AM
Backstrom's Avatar
According to Edins build thread they're stainless PRW 1,65 ratio pontiac rockers.
HWYSTR455
Jul 10, 2013 07:00 AM
CutlassLegend
Sep 21, 2011 02:56 PM
geckonz08
Feb 24, 2010 12:56 AM
rket56
Oct 20, 2009 09:49 PM
Redog
Aug 14, 2008 06:56 PM
