Replacing Intake Manifold
Old May 13th, 2011 | 06:14 PM
Stevec's Avatar
I just removed the intake and carb on a 68 400. Should I use the front and rear manifold gaskets or permatex? I am going to install an Edelbrock performer manifold and 600 cfm carb, any advice or tips would be greatly apreciated. Thanks!
Old May 13th, 2011 | 08:08 PM
firefrost gold's Avatar
permatex
Old May 13th, 2011 | 09:13 PM
ah64pilot's Avatar
Steve, I wouldn't use the rubber end gaskets. Instead, put a bead of Permatex Ultra black down on the block surface and then set the intake manifold straight down on it. As added insurance, you can take a center punch and punch 2 rows of dimples on the block and 3 or so rows on the bottom of the intake manifold end seal areas. When the Permatex dries, it will have "fingers" in these holes and will resist pushing out with crankcase pressure.
Steve
Old May 14th, 2011 | 03:41 AM
Stevec's Avatar
Thanks for the tip guys.
Old May 14th, 2011 | 07:42 AM
nice tip pilot,
shamusj
December 18th, 2014 10:28 AM
scooter123
May 24th, 2014 11:59 AM
svnt442
July 17th, 2011 05:43 PM
86pontiac
March 8th, 2010 06:06 AM
tbento
January 12th, 2007 10:47 PM
