Replacing Intake Manifold
Old May 13, 2011 | 05:14 PM
Stevec's Avatar
I just removed the intake and carb on a 68 400. Should I use the front and rear manifold gaskets or permatex? I am going to install an Edelbrock performer manifold and 600 cfm carb, any advice or tips would be greatly apreciated. Thanks!
Old May 13, 2011 | 07:08 PM
firefrost gold's Avatar
permatex
Old May 13, 2011 | 08:13 PM
ah64pilot's Avatar
Steve, I wouldn't use the rubber end gaskets. Instead, put a bead of Permatex Ultra black down on the block surface and then set the intake manifold straight down on it. As added insurance, you can take a center punch and punch 2 rows of dimples on the block and 3 or so rows on the bottom of the intake manifold end seal areas. When the Permatex dries, it will have "fingers" in these holes and will resist pushing out with crankcase pressure.
Steve
Old May 14, 2011 | 02:41 AM
Stevec's Avatar
Thanks for the tip guys.
Old May 14, 2011 | 06:42 AM
nice tip pilot,
shamusj
Dec 18, 2014 09:28 AM
scooter123
May 24, 2014 10:59 AM
svnt442
Jul 17, 2011 04:43 PM
86pontiac
Mar 8, 2010 05:06 AM
tbento
Jan 12, 2007 09:47 PM
