Rebuild oil pressure question
Old Mar 27, 2020 | 07:43 PM
Jhucks03's Avatar
Finally able to get far enough along with the install to prime the oil pump on a 455 I rebuilt. I’m seeing 40psi on an aftermarket mechanical gauge with a Dewalt drill on low speed (400ish RPM). Oil flow confirmed at all rocker arms.
Is 40psi acceptable?
Old Mar 27, 2020 | 07:48 PM
More than acceptable at 400 rpm with flow at all the rockers.
Old Mar 27, 2020 | 07:50 PM
Jhucks03's Avatar
Thank you very much. Hope to fire it up this weekend. Been a long time coming. All this corona stuff has got all the race tracks closed, so I’ve been able to spend a lot more time on my old ride here lately.
Old Mar 28, 2020 | 05:16 AM
rustyroger's Avatar
'87 Delta 88 Royale
400 rpm on the drill equals 800 rpm engine speed, 40 psi at fast idle with cold oil should be fine. Next step check out the pressure when the oil is at normal temperature. If it was my engine I'd be happy with the figures you have.
Roger.
Old Apr 20, 2020 | 06:03 PM
Jhucks03's Avatar
After some driving time, I have noticed that hot idle the oil pressure fluctuates 20-30psi. Slightest bit of throttle and it’s steady on 45. Am I being paranoid. Idle is a bit rowdy with the cam.
Old Apr 20, 2020 | 08:49 PM
Sugar Bear's Avatar
20-30 at hot idle is excellent. The oil dash lights switcj on at about 5 psi so you're in great shape.
Good luck!!!
chevyguru86
Mar 18, 2016 08:19 AM
ostie13
Sep 7, 2014 08:09 AM
Finn5033
May 15, 2012 05:53 AM
Ausraven
Feb 10, 2012 05:06 PM
tim72
Apr 1, 2010 06:27 PM
