Question about headers
Old Mar 12, 2019 | 12:57 PM
72455's Avatar
1972 U code Supreme
I have 72 U code Supreme and need to replace the headers. I prefer long tube, but from what I understand the engine needs to be removed. Is this true?
Old Mar 12, 2019 | 12:59 PM
svnt442's Avatar
No, but you will need to remove the oil filter adapter housing and you will need to raise the engine off the mounts to get them in.
Old Mar 14, 2019 | 05:37 AM
ronskal's Avatar
Plan on removing oil filter housing (3 bolts- need new gasket), removing the starter and jacking-up the front of the car some.
Old Mar 15, 2019 | 05:13 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Consider the Chinese Stainless headers, can't be beat for the price.
Old Mar 15, 2019 | 06:36 AM
72455's Avatar
1972 U code Supreme
Do you have more info?
Old Mar 26, 2019 | 02:09 AM
B964's Avatar
These?
https://www.ebay.com/itm/For-Olds-Cu...oAAOSwaGBbiOly
Old Mar 26, 2019 | 05:26 AM
There's no way a set of headers can be designed to fit the Cutlass AND the 65-70 Delta 88/98. The 65-70 Delta 88/98 were rear steer configuration. The only headers that will fit these cars would be fully custom. You can get reproduction exhaust manifolds from Thronton to run true dual exhaust though.
http://thorntonmusclecars.com/produc...aust-manifolds
For the OP, don't be fooled by manufacturers saying their headers will only fit the Cutlass and not the Cutlass Supreme or Cutlass S. This is a common error. Good luck with the install.
Old Mar 26, 2019 | 06:34 AM
Why not just go with the cast iron factory bolt on exhaust manifolds? They flow well and are a lot easier to install. They're what your car came with from the factory.
Old Mar 26, 2019 | 09:34 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Consider a starter heat shield(not a blanket) for either set-up.
Consider a head pipe blanket if you go with OEM manifolds/pipes.
Both the shield and pipe blanket will keep your starter healthy.
Old Mar 26, 2019 | 12:43 PM
That depends upon your definition of "well".
Old Mar 26, 2019 | 03:25 PM
Kenneth, they flow well enough to be used on W30's so that's good enough for me.
Old Mar 26, 2019 | 05:19 PM
W-30s used different exhaust manifolds than the "regular" 455 engines.
Old Mar 26, 2019 | 05:57 PM
How so? I don't see different manifolds listed in the parts manual for 72 455's. Keep in mind Dave's car is a U code and from factory they'd have put the most efficient exhaust on it they had. I know having the BBO dual exhaust system is significantly better than a crossover pipe system. I did put headers on my 350 once. I didn't like them and I honestly couldn't tell any difference in performance, so I ended up with an N10 blockoff plate. It works just fine, not as efficient as headers for sure, but good enough that my butt dyno doesn't worry about it.
Old Mar 26, 2019 | 07:37 PM
I'll defer to the fella who did dyno comparisons:
https://classicoldsmobile.com/forums...3-headers.html
The first thing I did to my ‘72 was headers and dual exhaust, night and day. The second thing I do was change the rear gear, again night and day.
Look on here, I did a header/manifold comparison. 30 hp and tq better with the headers throughout the rpm range. They’re one of the few things you can change the helps power AND mileage.
Old Mar 27, 2019 | 03:05 AM
savage'74's Avatar
Thornton headers
I put Thornton shorty headers on my '74,weren't too bad,but found a brand new set of blackjack full length for a very good price. Talking about throwback,lol,but installed with very little difficulty,didn't even have to drop starter. I would be interested in selling the Thornton if that's something you might want? They fit great and bolted right too the original true dual exhaust
Old Mar 27, 2019 | 04:45 AM
Ronniev's Avatar
If you do go with headers also go with a hi torque mini starter so you don't have hot start issues,that happened to me and the mini starter cured it.
Old Mar 27, 2019 | 05:02 AM
savage'74's Avatar
Header/starter
I've already installed the full length headers,have to say am very happy with them. Installation went well even,have been on a couple months now,and so far no starter issues,but that hot start problems i am very well aware of and am prepared to go the mini starter route if need be,thanks.
Old Mar 27, 2019 | 06:04 AM
savage'74's Avatar
Headers
Blackjack headers,'74 cutlass supreme,455
snylften
Jun 6, 2024 05:20 PM
oldzzy
Sep 12, 2016 05:30 PM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
jtriggy
Apr 17, 2010 05:23 PM
spikey0922
Jan 11, 2003 11:31 PM
