Quadrajet carb???
Old May 14, 2010 | 04:04 PM
Prsabordo's Avatar
Quadrajet carb???
Got a 4 brrl intake manifold finally for the 455, now i need a carb. What quadrajet works with it. It has the stove pipe setup. Casting number is 17030561. So through google, it was made from 1976-79, 4bbrl, from a pontiac with a manual trans. Will this work on my 4brrl intake manifold?
Old May 14, 2010 | 06:33 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
The pontiac linkage will probably hit your egr boss. It might not work unless you cut and weld the linkage a little bit. If you have room for a carb spacer, you can make it work.
Old May 14, 2010 | 08:39 PM
Prsabordo's Avatar
Do you know what quadrajets will work ?
Old May 15, 2010 | 06:57 AM
dc2x4drvr's Avatar
It would help to know what year Olds you're working on...if it's 70-72 any Qjet starting with "704" ie:7041250 should work with your manifold and throttle cable.
Old May 17, 2010 | 09:18 AM
Prsabordo's Avatar
im working on a 70 delta 88, got the intake manifold from a 70, i think, 98 w/455. Found a carb. Serial number is 7044502. I believe its a rochester 4mv, whatever that means. OK did some more research, the carb could've came off a 74 Chev /GMC/Truck 350/400/454. Will it work??
Old May 17, 2010 | 11:14 AM
dc2x4drvr's Avatar
My "decoder" says it's a '74 Olds carb, should do the job.
Old May 18, 2010 | 12:40 PM
Prsabordo's Avatar
Now will i have to get the rebuild kit for that specific carburetor or can i get one with regards to the car its being applied to (1970 delta 88 455)? How do i know what motor it came off of? If it came off of a smaller motor, will i have to upgrade the jets? dc2x4drvr: where can i find that "decoder"?
Old May 25, 2010 | 05:38 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Lots of info here. You need kit for carb.
http://www.carburetor.ca/carbs/tech/index.html
http://www.carburetion.com/carbinf.htm
auto_editor
Dec 20, 2010 11:24 PM
rtpassini
Mar 21, 2010 04:41 PM
1964CutlassSC
Feb 18, 2010 08:05 PM
sanemb
May 28, 2008 05:43 PM
1FSTLS1
Mar 4, 2008 06:48 AM
