First time I saw this
Old May 22, 2010 | 08:44 PM
MN71W30's Avatar
We pulled a good running 69 G block 400 out of a 442 today to install a tri carb 455. We decided to use the flywheel from the G block but it wouldn't fit the 455. The holes wouldn't line up. The G block has provisions for a piliot bearing and appears to have a steel crank according to the notch in the back of the crank.
The only thing we can come up with now is that the G block has a 65-67 400 or 425 crank. If thats the case, I'm thinking the cubes must be around 375 or so. Anyone have another explanation? We installed a flywheel off a 455 we had in stock and got it in and running.
Old May 22, 2010 | 11:23 PM
svnt442's Avatar
It could be an early 455 crank, but the only way to know for sure what's in there would be to drop the pan and look.
Old May 23, 2010 | 07:12 AM
MN71W30's Avatar
Thanks Randy,
I read through the 442.com info and were hoping that the crank is an early 68. It is steel like the early ones were and drilled for a stick. I should have bought the motor myself he sold the block and C heads for $500 and it runs nice.
Old May 23, 2010 | 08:29 AM
88 coupe's Avatar
Junior Member
Originally Posted by MN71W30
........ I'm thinking the cubes must be around 375 or so .........
Those blocks came out of the factory with two bores, and the cranks came out of the factory with two strokes. No matter how you "mix and match" them, you will get 400, 425, or 455 inches.
Edit: If stock parts are used.
Originally Posted by svnt442
........ but the only way to know for sure what's in there would be to drop the pan and look.
More accurate to remove a head and measure the stroke at TDC and BDC. The difference between 4" and 4¼" will be obvious.
Norm
Old May 23, 2010 | 09:15 AM
Norm
Better check your math, Norm. The stock bore in a G-block 400 is 3.870". Stock stroke of a 65-67 BBO crank (400 and 425 are the same) is 3.980". I get 374.5 cu in from that combo.
Old May 23, 2010 | 02:17 PM
88 coupe's Avatar
Junior Member
........ Edit: If stock parts are used ........
Which piston/rod combination would you be using in that engine?
Norm
Old May 23, 2010 | 04:01 PM
MN71W30's Avatar
LOL, Norm, Did you have a rough weekend?
Old May 24, 2010 | 09:26 AM
88 coupe's Avatar
Junior Member
........ Did you have a rough weekend?
Did you read something that I did not write?
Norm
Old May 24, 2010 | 09:35 AM
aliensatemybuick's Avatar
"me somebody" site member
If indeed an early 400 or 425 crank and rods were used, I'd be curious to know what pistons would work. Custom made? In other words, how could you POSSIBLY mix and match a G block with the earlier crank using ALL stock parts?
And what's this about an "early" 68 crank? Why would that have a different bolt pattern?
Old May 24, 2010 | 10:28 AM
MN71W30's Avatar
Thats the million dollar question. If there is a chance that a 400 short stroke crank and rods were used in a G block. The pin size and location would have to be the same . I thought someone would know if it is even possible without me having to research this on my own. We don't really want to pull the pan or heads because the motor runs fine.
Norm, Answer Joes question first, at least read it, he made it very clear.
I don't want to argue,
Old May 24, 2010 | 12:10 PM
88 coupe's Avatar
Junior Member
........ Answer Joes question first ........
What question did he ask?
Norm
Old May 24, 2010 | 12:27 PM
Now that I think of it, I know I have read in the past about someone using an early 400/425 crank and rods in a G block with a mild overbore (maybe 0.030 over?) and custom made pistons. Was someone who wanted the appearance of a "matching numbers" car but hated the performance of the stock 400. Was an old post on ROP that may no longer exist, but assuming my memory is correct, its possible because its been done. I remember thinking that it was a lot to go through, but cool nevertheless.
Old May 24, 2010 | 12:49 PM
Exactly. That's why I (as others) suggested the early crank in the G-block. Note that there are actually SIX possible bore/stroke combinations available using stock blocks and cranks:
Early crank (3.980 stroke) x A/D/F block (4.125 bore) = 425.5 cu in
Early crank (3.980 stroke) x B/E block (4.000 bore) = 400.1 cu in
Early crank (3.980 stroke) x G block (3.870 bore) = 374.5 cu in
Late crank (4.250 stroke) x A/D/F block (4.125 bore) = 454.4 cu in
Late crank (4.250 stroke) x B/E block (4.000 bore) = 427.3 cu in
Late crank (4.250 stroke) x G block (3.870 bore) = 399.9 cu in
Yes, the "455" Olds is really a 454...
Old May 24, 2010 | 12:57 PM
MN71W30's Avatar
Norm,
Your statement
"Those blocks came out of the factory with two bores, and the cranks came out of the factory with two strokes. No matter how you "mix and match" them, you will get 400, 425, or 455 inches.
Is very misleading and if your trying to imply that the parts would have to be stock as your edit might sugggest "If stock parts are used" to the generation of blocks, the statement still is very misleading and unnessary and doesn't clarify or add anything usefull to the thread.
You then ask what combination of rods and crank would be used. It was mentioned several times what the combination would be, I would hope your smart enough to allready know the answer to that, so why ask?. There could only be one combination that would achieve 374 CI.
By the way, In this situation with .250 difference in strokes, removing the head is no more accurate than pulling the pan and measuring or finding a casting number on the crank. Infact it is a much more costly alternative. An intake gasket and head gasket are several times more expensive than a pan gasket. Again, that is poor advice.
Your right about one thing, Joe didn't ask a question.
Old May 24, 2010 | 01:01 PM
MN71W30's Avatar
Joe,
Is there a crank with a 4.25 stroke with the 65-67 400 425 bolt pattern?
Old May 24, 2010 | 01:06 PM
Joe,
Not that I am aware of - at least not with "stock" parts. It is possible to offset grind the early crank, of course, and get a 4.250" (or some other number) stroke, forged crank. Why you'd waste this in a G-block is a mystery to me, but Olds specialty houses sell cranks configured like this.
Old May 24, 2010 | 01:16 PM
MN71W30's Avatar
Thanks Joe,
What ever happened to this engine, it happened decades ago.
Old May 24, 2010 | 03:37 PM
Exactly. That's why I (as others) suggested the early crank in the G-block...
I understood that from the original post....I was asking specifically what was meant by "early 68" crank, as mentioned by others in this thread including the O.P. Just wanted to make sure I wasn't missing something, as I thought that while there were some forged steel '68 cranks, they still would have the later flywheel bolt pattern. That is all I was asking there.
I'm curious what the displacement would be for an "early" 400/425 crank in a G-block bored say .060 over? Somewhere around 387 C.I, or about 97% of an E-block's? I bet a 68-69 owner would be very happy with the performance of such a combo, even if all else was kept stock.
Old May 24, 2010 | 03:43 PM
MN71W30's Avatar
Thats what we were hoping for, the earlier bolt pattern on a later crank. But it may not be true.
Old May 24, 2010 | 04:51 PM
wmachine's Avatar
Trying to remember member
No "early '68" cranks with the pre-'68 pattern. The pattern was changed because they type of balancing changed. I'll defer to Joe P for further explanation.
Old May 24, 2010 | 05:15 PM
MN71W30's Avatar
Thanks Kurt,
It looks like we got us a 375 Rocket motor.
Old May 24, 2010 | 06:21 PM
88 coupe's Avatar
Junior Member
........ Is very misleading and if your trying to imply that the parts would have to be stock as your edit might suggest ........
Do you think it is logical, that someone might go to the time and expense of using custom parts, in order to achieve a significant loss in power?
........ the statement still is very misleading and unnecessary and doesn't clarify or add anything useful to the thread. ........
And this statement is not a mature contribution to a productive discussion.
........ You then ask what combination of rods and crank would be used ........
Why would you think it not a legitimate question?
........ It was mentioned several times what the combination would be ........
Where was it mentioned?
........ I would hope your smart enough to already know the answer to that, so why ask? ........
Nothing to do with "smart". Everything to do with the reason boards like this exist. When questions are asked, and answered, learning happens.
........ There could only be one combination that would achieve 374 CI. ........
That displacement is not achievable, using stock parts, hence my question to joe_p.
On the other hand, if custom parts were used, there would be hundreds of displacement possibilities.
....... removing the head is no more accurate than pulling the pan and measuring or finding a casting number on the crank
Wouldn't the piston/rod assembly make it hard, if not impossible, to get an accurate measurement of the cylinder dimensions? Would the casting number show if the stroke had been altered?
........ In fact it is a much more costly alternative ........
Considering the amount of information that can be found under a head vs an oil pan, why would anyone want to "cheap out"?
........ Again, that is poor advice.
Depends whether one wishes to sacrifice quality, in order to save a couple of dollars.
........ The stock bore in a G-block 400 is 3.870". ........
That would be the third bore diameter I failed to include.
Its 6.735" rod and 1.74" compression height, when combined with a 3.98" stroke, would place its piston top about .160" below the deck. An easy 374 inches, if one can live with an extreme lack of power.
Now, if the bore was increased to 4" in order to use "early" 400 pistons (1.615" compression height) with 7" rods, and a 3.98" stroke, it would have the same spec's as an "early" 400, including the flange pattern.
........ Yes, the "455" Olds is really a 454...
Better check your math, Joe. This time use 4.126" for the bore.
Norm
Old May 24, 2010 | 06:23 PM
Thanks Kurt,
Or, more likely, a custom-ground early forged crank. It will be interesting to measure the actual rods and crank throws on this motor.
Old May 24, 2010 | 06:46 PM
You're really suggesting a greater than 1/8 inch overbore on a G block is possible, huh? Guess that's one way to get the displacement into the range of possibilties you originally offered.
Old May 24, 2010 | 06:57 PM
88 coupe's Avatar
Junior Member
Not only possible but, in this case, highly likely.
Norm
Old May 24, 2010 | 07:10 PM
Norm
Sure.
Old May 24, 2010 | 07:16 PM
MN71W30's Avatar
Norm most of your last post was not worth reading., however this information is very useful.
Norm
That is a possibility but would require a .130 over bore on a G block. It would then be a simple installation of a roating assembly from a 4 in. stroke rotating assembly. It may be the most logical scenero next to a custom crank as Joe mentioned. My friend is unable to pull the pan this week, I told him to get a piston diameter also. I'll be sure to post the findings.
Aliensatemybuick, We had a 324 bored .125 over years ago. It will be interesting to find out. It does seem extreme.
Old May 25, 2010 | 11:45 AM
507OLDS's Avatar
"Maybe" they used the shorter stroke 400/425 crank,with the 7" rods,& a 350 piston.I've seen some things like that done before.
Old May 26, 2010 | 06:16 AM
88 coupe's Avatar
Junior Member
Originally Posted by 507OLDS
........ 7" rods, & a 350 piston. ........
Good call.
Norm
Old May 26, 2010 | 08:09 AM
But that would bring it to 4.057" bore, even a greater overbore (of 0.187")? HOW about a 330 piston (if this is an absurd suggestion, I apologize in advance).
I guess an investigation of the motor itself will tell...assuming it is from the underside, I presume a precise measure of the bore can be made with the rods in the way?
Old May 26, 2010 | 08:20 AM
  #31
Rolling it around, I'm really liking my theory, as it involves using stock parts and a mild overbore. An application of Occam's razor? This would be ths same basic build as I suggested in my post (#18) above, with the advantage that custom pistons would not be needed.
Old May 26, 2010 | 09:46 AM
  #32
88 coupe's Avatar
Junior Member
........ how about a 330 piston? ........
Another good call.
Norm
Old May 26, 2010 | 11:50 AM
  #33
507OLDS's Avatar
I had some old Jahns flat tops for a 330,& that is what they got used for.Heck,maybe it's that motor.
truerollers
Feb 28, 2017 01:00 PM
Slater442
Nov 23, 2012 11:29 PM
ccnclassicoldsmobile
Jul 31, 2012 09:17 AM
rgass
Feb 19, 2011 08:13 PM
made in the usa
Dec 19, 2010 04:43 PM
