Progress on the 455....
Old Jun 24, 2012 | 05:06 PM
Delmont 88 PA's Avatar
Well, I almost have a proper short block. Everything is assembled except for the oil pump--I need to get a gasket for the pickup tube to pump flange. The oil pan is in place for pictures but will come off tomorrow and the oil pump will be installed.
The side shot of the engine is rotated 90 degrees. The other photo shows where I opened up the drains between the lifters--ground away the rough castings (figured that I might as well since the crank was pulled out to grind the bottom of the cylinders to make room for the Eagle rods.
Now, if the heads are decent on the 425 that is in the car--with a cracked block from freezing and only 28K original miles --I should have a whole engine in 2 weeks.
Old Jun 24, 2012 | 05:33 PM
Gator69olds's Avatar
It's looking good!!
Old Jun 24, 2012 | 05:40 PM
Thanks! Hopefully it will run....
Old Jun 24, 2012 | 05:44 PM
Always have faith in yourself!
Old Jun 26, 2012 | 01:53 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Nice color scheme on that block :d
Old Jun 26, 2012 | 01:54 PM
Olds Specialist LOL
Originally Posted by gator69olds
always have faith in yourself!
yeS because nobody else will!!!
panos
Feb 2, 2011 10:39 AM
Eddie Hansen
Apr 11, 2010 07:01 AM
MN71W30
Feb 20, 2009 01:16 PM
dar83501
Oct 6, 2007 01:32 PM
ct1979
Mar 11, 2007 03:51 PM
